Radiator Hose Blew, Need Help
Old Jan 17, 2003 | 03:47 PM
Mike_C's Avatar
Default Radiator Hose Blew, Need Help
Yes, I'm a tech newbie (flame suit on).
Anyway, my upper radiator hose blew yesterday, I was able to get home before I overheated.
I got a new hose, trimmed it, and installed it.
I then filled up with the proper coolant/water mixture and started the car.
For a minute it idled fine and then it began jumping from about 1500rpm-2000rpm.
RJ says I need to bleed air out of the system but his methods were very cryptic.
I'd like to be able to drive tonight but this isn't an emergency or anything so I'd appreciate any help I can get.
The car is a '91 Accord DX Auto.
Old Jan 17, 2003 | 03:54 PM
urbanlegend21's Avatar
New User
Default Re: Radiator Hose Blew, Need Help (JMU1337)
you at JMU tonight?
I am down here
Old Jan 17, 2003 | 03:55 PM
Mike_C's Avatar
Default Re: Radiator Hose Blew, Need Help (urbanlegend21)
WTF! I told you to tell me the details on that GGW thingie. Anyway yes, 1023F South View... you've been here.
Old Jan 17, 2003 | 03:59 PM
jspark79's Avatar
Run the car with the cap off
& make sure you put the right amt of coolant
Old Jan 17, 2003 | 04:00 PM
Mike_C's Avatar
Default Re: Radiator Hose Blew, Need Help (jspark79)
Sounds too easy...
Old Jan 17, 2003 | 04:03 PM
jspark79's Avatar
My radiator blew over the summer & my friends and I changed & installed a new radiator.
When we finished, we ran coolant in, started the car and filled more coolant with cap off. The air runs through bubbling through the opening. This is what we did on my car. Havent had trouble since.
Old Jan 17, 2003 | 04:15 PM
Mike_C's Avatar
Just tried that.
Car started fine, cold idle was around 1800rpm but it kept gaining. Around 2200rpm it almost felt/acted like there was a fuel cutoff and it would drop to about 1500rpm and go back up to 2500rpm, drop again, go up again, etc.
Old Jan 17, 2003 | 04:19 PM
jspark79's Avatar
Is it possilbe that it can be something else other than that hose you replaced?
Maybe it burst for a reason. Wish I could you more bro
Old Jan 17, 2003 | 04:21 PM
Mike_C's Avatar
Dunno, I may just have to call AAA to come out and tow it
edit: I'll play with it more with Mr. RJ tomorrow before doing so.
[Modified by JMU1337, 1:24 AM 1/18/2003]
Joseprz
14
Aug 25, 2009 05:05 PM
PatrickGSR94
Aug 19, 2008 03:48 AM
I3ooS710
Mar 25, 2006 03:45 AM
wld2rde
Feb 10, 2005 05:54 AM
