IAC valve removal??
Old Jan 17, 2003 | 03:30 PM
stRtypR25's Avatar
Default IAC valve removal??
when removing the IAC valve, when you remove the hoses, does coolant start leaking out. i guess my question is, do you have to drain the coolant??
Old Jan 17, 2003 | 03:45 PM
sgT's Avatar
sgT
Default Re: IAC valve removal?? (stRtypR25)
you dont have to drain it.
either clamp the hoses or work quickly
Old Jan 17, 2003 | 03:49 PM
stRtypR25's Avatar
Default Re: IAC valve removal?? (sgT)
thanks for the infor SGT, i guess i am going to drain the coolant, i do not want coolant spilling all over the place.
Old Jan 17, 2003 | 07:43 PM
uNF$@#!'s Avatar
coolant tastes like koolaid. .. dont be afraid! Come on!
I'd drain it too
Old Jan 18, 2003 | 04:24 AM
HondaCivicEx98's Avatar
New User
Default Re: IAC valve removal?? (Soup ****)
U dont have to drain it at all, just clam it or put them face upwarps so it wont leak.
Old Jan 18, 2003 | 04:49 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
I'd drain it too
that would be a waste of time/effort. pull the hoses and install them on the new iac. then unbolt the old one, then bolt on the new one. simple, and very minor spillage. basically what sgt said: work quickly swapping the hoses.
91akira
May 11, 2017 11:40 AM
White_EG1
Sep 18, 2016 11:41 AM
Acidcrakker
Dec 9, 2007 04:14 PM
91crxturbo
Aug 22, 2007 03:28 AM
n0rmaL
Dec 1, 2006 04:40 PM
