cylinder 4 still misfiring....help!!!
Old Jan 17, 2003 | 11:20 AM
Hang On's Avatar
Default cylinder 4 still misfiring....help!!!
hey guys...ok so far i changed both the spark plugs and the wires on my gsr motor. when the car is at idle it runs smooth but there is a scattered sound, best way to describe te sound is something is loose and is rattling around. when i give a little gas the noise just gets louder. i just had the motor built with Je 9:1 pistons (.020 over), eagle rods blah blah blah...any suggestions on what i should check next? i don't want to just start taking things apart without some advice first....thanks
Old Jan 17, 2003 | 11:24 AM
wilsel's Avatar
Default Re: cylinder 4 still misfiring....help!!! (Hang On)
Have you checked the distributor cap? Has the motor ran correctly since the rebuild?
Old Jan 17, 2003 | 11:25 AM
b16 matt's Avatar
Default Re: cylinder 4 still misfiring....help!!! (wilsel)
wilsel. good call.
Old Jan 17, 2003 | 11:27 AM
Hang On's Avatar
the motor ran fine sinse the rebuild and only had the codes coming up about the O2's...then all i did was lengthen the primary wires and then the misfire started. no i didn't ceck the distributor yet..what should i be looking for?
Old Jan 17, 2003 | 12:36 PM
00MRSi's Avatar
Talk to CHEETAH/Greg on this board. He lives in Central Jersey and he can help you.. Look for his name on this board.. Good luck..
Old Jan 17, 2003 | 01:42 PM
B18EG6's Avatar
Check the distributor rotor too...
check to see if there are deposits on the terminals inside the cap, and see if the rotor looks burnt.
I just replaced mine yesterday, fixed my problem. Ill post pics in a sec, hold on lemme take some
[Modified by B18EG6, 5:42 PM 1/17/2003]
Old Jan 17, 2003 | 01:55 PM
B18EG6's Avatar
Default Re: cylinder 4 still misfiring....help!!! (B18EG6)
one more thing...also, did you check the resistance of your wires? none of them should be above 25 kilaohms. Do you have a multimeter to test them? its real easy
here, i took some quick pictures of my burnt shat. Sorry if some of them are fuzzy.
See how the edge looks a little brown? Mine was burnt pretty bad so I replaced it.
Here is the distributor cap. There are whiteish deposits on the terminals, see them?
also, here is the center 'axis' of the rotor. There are lots of black deposits on this, I wiped them off to see if it was black or not...so they're kinda gone in the middle. Looks like soot
hope this helps
edit- also check for coolant/rain or whatever might have leaked into the dist cap. This was the cause of mine, a coolant line popped off and sprayed its skunky fury all over the place
[Modified by B18EG6, 5:57 PM 1/17/2003]
Old Jan 17, 2003 | 03:02 PM
Hang On's Avatar
thanks for all te help guys i appreciate it. cheers!
Old Jan 17, 2003 | 03:32 PM
B18EG6's Avatar
GSR Distributor rotor:
06304-P72-000
$25.30
comes with dust cap and new diamagnetic screw for the rotor
kshgl87
Dec 23, 2007 11:07 AM
Al-sonic
Jun 27, 2007 04:22 PM
x_tc-Dae
Oct 7, 2004 01:07 PM
mykem
Dec 1, 2003 05:54 PM
Fatty_1775
Jul 13, 2003 06:32 AM
