Help! Starting problem
Alright this started to happen all within a week. first my car started to make some like whining noises from the distributor area. after i take it on the highway the noise was gone so i thought nothing was wrong. then couple of days later when i start to press gas it sounds like i have lot of air going in to my car. then that sound stopd after a day or two. now my car is having trouble starting. when ever i start it starts for little bit and it turns off, but when i start driving its fine, when i stop it turns off. now i was thinking it was the spark plugs, wires, and the distributor but im not queit sure if that is going to do it. you guys have any ideas? thanks
Re: Help! Starting problem (ghost face)
check the plugs and plug wires and the rotor cap.
Once you're done there, check the Idle screw in the throttle body.
Re: Help! Starting problem (Spade)
yea your rite, i changed the spark plugs and wires on my car like 30 minutes ago ran pretty good. im going to change the rotors after i get off work, but i was wonderin what would be a good idle for my car 92 civic vx 1.5l. i think mines probably idling between 500-700 .
jdmstylez16
10-28-2007 02:39 PM
itsm3paul
05-10-2004 12:49 PM
