Rod Bearings...
Old Jan 17, 2003 | 11:01 AM
Evil EG's Avatar
Default Rod Bearings...
What is the OEM honda part number for Black and Brown Bearings for a 00GSR?
Old Jan 17, 2003 | 11:16 AM
Evil EG's Avatar
Default Re: Rod Bearings... (BVM)
Well I got 6browns and 2blacks
Some of them didnt look like they had colors on them and one looked green.
So can some one check these numbers-
Brown - 13213-P72-003
Black - 13211-P72-003
Thanks
Old Jan 17, 2003 | 01:11 PM
Evil EG's Avatar
anybody...
Old Jan 17, 2003 | 04:35 PM
Evil EG's Avatar
I guess I just wont use rod bearings...their overrated anyway!
Old Jan 17, 2003 | 04:38 PM
earl's Avatar
Use ACL rod bearings and quit worrying about colors. Contact Camp1320 as he has a special on them.
Old Jan 17, 2003 | 04:43 PM
Evil EG's Avatar
Default Re: Rod Bearings... (earl)
I already bought the OEM honda ones.
I just want to varify the part numbers cause I dont trust the place I got them from and I think they gave me the wrong ones.
Old Jan 18, 2003 | 12:09 AM
Rocket's Avatar
I agree with Earl, go with the ACL's even if you have already bought the OEM ones.
IMO, ACL are good for 1000hp.
Old Jan 18, 2003 | 01:35 AM
Flamenco-T's Avatar
look at the bearing from the side, it should be marked with colored ink, if it's green, there should be a green marking on it's side...
but get ACl...
Old Jan 18, 2003 | 05:26 AM
tony1's Avatar
Default Re: Rod Bearings... (Flamenco-T)
I guess i'm the oddball here. I would stick with the oem honda bearing. The gsr rod bearings have some sort of teflon coating on them and even a lot of nascar and other v8 guys use oem gsr rod bearings if that tells you anything. We run oem bearings as well...
Old Jan 18, 2003 | 06:37 AM
b19coupe's Avatar
Default Re: Rod Bearings... (tony1)
I always run OEM bearings and have not had one bearing failure, ever. I can get the part numbers for you a little later today.
Old Jan 18, 2003 | 07:40 AM
earl's Avatar
Default Re: Rod Bearings... (b19coupe)
If you really want to know which bearing is which, get a bearing mic and follow this list:
Blue 1.510-1.507mm
Black 1.507-1.504
Brown 1.504-1.501
Green 1.501-1.498
Yellow 1.498-1.495
Pink 1.495-1.492
Red 1.492-1.489mm
If you want the same info on mains, first send a $1000 donation to my favorite charity, the Arturbo Home for Wayward Women
Old Jan 18, 2003 | 09:10 AM
b19coupe's Avatar
13211-P72-003-Blue.
13212-P72-003-Black.
13213-P72-003-Brown.
13214-P72-003-Green.
13215-P72-003-Yellow.
13216-P72-003-Pink.
13217-P72-003-Red.
Old Jan 18, 2003 | 09:11 AM
Evil EG's Avatar
Well I called acura today and found out what my bearings were.
As I suspected they were not black.
Part Number 13211-P72-003 was blue.
So looks like my engine build is put on hold for another couple days.
d16dcoe45
Sep 26, 2006 08:24 AM
GSRCRXsi
14
Jul 11, 2005 07:09 PM
turbo96wr
May 26, 2005 09:42 AM
Dee
Mar 7, 2002 08:01 PM
