Rod Bearings...
Well I got 6browns and 2blacks
Some of them didnt look like they had colors on them and one looked green.
So can some one check these numbers-
Brown - 13213-P72-003
Black - 13211-P72-003
Thanks
Thanks
I already bought the OEM honda ones.
I just want to varify the part numbers cause I dont trust the place I got them from and I think they gave me the wrong ones.
I guess i'm the oddball here. I would stick with the oem honda bearing. The gsr rod bearings have some sort of teflon coating on them and even a lot of nascar and other v8 guys use oem gsr rod bearings if that tells you anything. We run oem bearings as well...
If you really want to know which bearing is which, get a bearing mic and follow this list:
Blue 1.510-1.507mm
Black 1.507-1.504
Brown 1.504-1.501
Green 1.501-1.498
Yellow 1.498-1.495
Pink 1.495-1.492
Red 1.492-1.489mm
If you want the same info on mains, first send a $1000 donation to my favorite charity, the Arturbo Home for Wayward Women
Blue 1.510-1.507mm
Black 1.507-1.504
Brown 1.504-1.501
Green 1.501-1.498
Yellow 1.498-1.495
Pink 1.495-1.492
Red 1.492-1.489mm
13211-P72-003-Blue.
13212-P72-003-Black.
13213-P72-003-Brown.
13214-P72-003-Green.
13215-P72-003-Yellow.
13216-P72-003-Pink.
13217-P72-003-Red.
13216-P72-003-Pink.
13217-P72-003-Red.
Well I called acura today and found out what my bearings were.
As I suspected they were not black.
Part Number 13211-P72-003 was blue.
So looks like my engine build is put on hold for another couple days.
