Rear disc brake conversion.
Old Jan 17, 2003 | 07:19 AM
lastlude2k1se's Avatar
Default Rear disc brake conversion.
Around how much am I looking at for a GSR rear disc brake conversion on an EG6? Thanks
Old Jan 17, 2003 | 07:55 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Rear disc brake conversion. (lastlude2k1se)
If you want the car to stop better then do the rear discs LAST.
Rear discs alone won't help you car stop any better for ****.
I recommend doing the Integra front brakes forst with either a 1991 Civic EX 4-door master cylinder or a 1994-1995 Integra RS only booster and master cylinder combo.
My fiancee' has a 1992 Civic Si with 4-wheel discs and it doesn't stop nearly as good as my pal's 1993 Dx hatch with GS-R front brakes with RS booster and m/c and stock rear drums.
Old Jan 17, 2003 | 07:56 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Oh and for any parts call:
1-800-962-8922
Import Auto Salvage.
Ask for Larry Jr. or Randy. Tell them Tom from Georgia sent you.
They'll have front and rear discs and all of the other Integra brake stuff you'll need if you must go 4-wheel discs.
Don't get me wrong - I have all 4 cornmers of GS-R brakes, but I'd never do rear discs with stock Civic-sized front brakes.
Old Jan 17, 2003 | 08:15 AM
Default Re: Rear disc brake conversion. (B18C5-EH2)
The 1993 DX hatch came with rear discs? I thought it came with rear drums?
Old Jan 17, 2003 | 09:17 AM
ejprimo's Avatar
tom, have you found out which combo is better? the RS mc and booster or the 91 ex 4-door mc and stock booster?
Old Jan 17, 2003 | 09:21 AM
EVIL Hx Coupe's Avatar
Default Re: Rear disc brake conversion. (ejprimo)
I'd like to know also.
Old Jan 17, 2003 | 09:27 AM
splitime's Avatar
me three! splitime...whos waiting to clean up his 4disc setup for install.
Old Jan 17, 2003 | 11:39 AM
kommon_sense's Avatar
Rear discs make it a little more balanced, but they aren't the big braking upgrade that everyone things they are. (found this out after putting rear discs on my ex).
I agree, upgraded fronts should be the first order of business.
My fiancee' has a 1992 Civic Si with 4-wheel discs and it doesn't stop nearly as good as my pal's 1993 Dx hatch with GS-R front brakes with RS booster and m/c and stock rear discs.
Interesting, but to shed a little more light on this, the GSR has larger front calipers than the EX/SI.
Old Jan 17, 2003 | 11:40 AM
I got my rear setup from Import Auto Salvage for $275+shipping. Came with all cables, and prop valve. I didn't need the MC/booster (EX has same ones as SI). Also don't forget to add money for brake fluid, new rear rotors and pads, and possibly SS lines.
Old Jan 17, 2003 | 12:14 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Thanks, I had a typo.
Old Jan 17, 2003 | 12:19 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Rear disc brake conversion. (kommon_sense)
Yes. That's exactly my point.
Rear discs with stock-sized Civic fronts aren't worth a **** when compared to Integra front brakes with a bigger m/c and booster even if the car with Teg fronts still has stock drums in the rear.
j me4door
Mar 6, 2009 07:06 AM
eg8ynot
Nov 6, 2008 04:43 PM
89 civic si
Oct 26, 2006 06:42 PM
Stryker908
Nov 21, 2002 06:09 PM
