225/50r15???
Old Jan 17, 2003 | 12:14 AM
FRESH's Avatar
Default 225/50r15???
I wnat to put a 225/50r15 on some ssr comps.. How bad do you think they would rub on a crx? i have eibach prokit springs and plan on gettin koni yellows.. I have the energy susp bushing kit if that matters.. Cause i want some wide tires for more traction since my **** is so light.. and they make some nice tires in taht size and the new bfg drags along with the bfg kd whatevers....
Old Jan 17, 2003 | 02:22 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: 225/50r15??? (FRESH)
on the street? if you are getting race tires, and want 225's, get kumhos ecsta 225/45-15's. they are narrower (and more durable) than the hoosier 225, but wider that than the 205 and are not too tall. as far as the street goes, a 205/50 is fine.
Old Jan 17, 2003 | 08:41 AM
Todd00's Avatar
I said I don't want a title!
That's a freakin huge tire. They barely fit under and Integra, let alone a lowered CRX. Plus, the tire would kill your gearing as it is much too tall.
Old Jan 17, 2003 | 12:14 PM
FRESH's Avatar
Default Re: 225/50r15??? (Todd00)
well ****.. i just want somemore rubber.. ******* hondas.....i guess thats what i get for havin a tiny crx...
Old Jan 17, 2003 | 03:18 PM
b16_madman's Avatar
see if some spacers work or someting....i wanna be wider also...currently 205's chirps 2nd w/I n E b16 sumitomos 200's or so
Old Jan 17, 2003 | 04:39 PM
bryant's Avatar
Default Re: 225/50r15??? (B16_madman)
If your cars lowered at all. 205+ is going to rub.
EDIT: depending on how much its lowered and tire.
[Modified by Bryant, 6:39 PM 1/17/2003]
Old Jan 17, 2003 | 05:06 PM
Crxer's Avatar
Default Re: 225/50r15??? (Bryant)
205 tires is probably the widest you can go without hitting when turning...
i got 205/40/16 with a 43 offset. im guessing if you get a good offset you can maybe stretch it to 215, but maybe the tire will stick out a little..
Old Jan 18, 2003 | 12:04 AM
FRESH's Avatar
Default Re: 225/50r15??? (efzero.com)
thanks guys..
Old Jan 18, 2003 | 12:10 AM
matt j's Avatar
i am running 215 40 16s on my hatch, i had to roll the rear fender well a little bit and as for the front the only time they rub is when i hit a hard *** bump
whited
10
Aug 19, 2013 08:56 PM
wfocrx
Apr 4, 2007 11:17 AM
supracrx
May 2, 2006 06:22 PM
apexinghonda
Feb 27, 2006 11:21 AM
SiRex91
14
Nov 14, 2002 04:12 AM
