T04 compressor housing bolt pattern the same as T3?
Old Jan 16, 2003 | 08:17 PM
Bontke's Avatar
Default T04 compressor housing bolt pattern the same as T3?
Here's my delima. I am trying to piece together a turbo kit for my B18B. I have an old T04 housing lying around collecting dust. I also have a stock turbo off a 88 RX7. What I need is a manifold. I believe that I can make an adapter plate for the RX7 turbo to a T04 housing. Most manifolds that I have looked into for the B18B bolt up to T3 turbo housings. I would like to get a manifold for a T3 allowing me to upgrade in the future to a custom T3 turbo setup, the T04 is too big...at least for my application. I am trying to decide if i can make an adapter for a T3 manifold to the RX7 turbo. I have never dealt with T3's in the past and don't know much about them or the manifold bolt patterns. So how similar are the T3 and T04 manifold bolt patterns?
Old Jan 22, 2003 | 06:16 PM
Bontke's Avatar
Default Re: T04 compressor housing bolt pattern the same as T3? (Bontke)
Come one someone has to know or at least had the two housings side by side.
[Modified by Bontke, 9:16 PM 1/22/2003]
Old Jan 22, 2003 | 07:03 PM
lazerus's Avatar
you have to have the T-4 backing plate to bolt it on onto a T3 turbocharger.
Old Jan 22, 2003 | 09:26 PM
Bontke's Avatar
Default Re: T04 compressor housing bolt pattern the same as T3? (lazerus)
Can you elaborate on that? I am confused by your answer.
Old Jan 28, 2003 | 04:43 AM
Bontke's Avatar
Well, someone else out there with turbo manifold experience?
Old Jan 28, 2003 | 05:28 AM
Smashback's Avatar
I think the was going by your title...you asked about a compressor housing but I think you are asking about the turbine housing (the hot side).
If you're asking if a T4 will bolt up to a T3 manifold and vice versa, then no, the flanges are different.
Old Jan 28, 2003 | 05:15 PM
Bontke's Avatar
Default Re: T04 compressor housing bolt pattern the same as T3? (Hatchblack)
Man, I can never get that stuff right. Mainly my interest is how similar that the turbine housings are bacause I have a RX7 TII turbo that had a similar turbine housing to a T04. If the T3 turbine housing is similar in length and width (not too much smaller) to the T04 then I could make an adapter for the RX7 TII turbo to T3 housing.
Silvertc
Dec 29, 2008 10:56 PM
coupe_hybrid
Dec 4, 2006 07:21 AM
1SIKCRX
Oct 9, 2003 08:13 PM
EV1L SI
Jul 13, 2003 11:12 AM
smslude
May 2, 2003 02:01 PM
