Wierd gas problem, help.
Old Jan 16, 2003 | 08:05 PM
turbo_civic's Avatar
Default Wierd gas problem, help.
Ok, i have a 91 civic hatch, when then tank is near empty then the car drives good, like it should, and has *****, as soon as i got to the pumps and put in gas, it lags when i step on the throttle and has half the ***** as it would normally have, then after a few days when the needle is back to almost empty then i get power form it again.
Old Jan 16, 2003 | 09:44 PM
s73's Avatar
s73
New User
Default Re: Wierd gas problem, help. (4thGenTurbo)
could it be the added weight of the full tank of gas?
Old Jan 16, 2003 | 10:09 PM
Default Re: Wierd gas problem, help. (s73)
Man, 1 liter weighs 1 pound, so i dont think that 13 extra pounds will matter(thats how many liters you get for 10 bucks here), lol, i only put in $10 at a time, however could it be the extra volume of fuel in the gas tank is causing it?
[Modified by 4thGenTurbo, 7:10 AM 1/17/2003]
Old Jan 17, 2003 | 03:20 AM
EKFerioHawaii's Avatar
Check your fuel system pressure. If there is, locate the leak and fix it.
Um... I've heard of fuel pumps going bad having the same symptoms you do. See if you can borrow someones fuel pump for the day and see if that makes a difference.
Old Jan 17, 2003 | 06:13 AM
88_SC_CRX_Si's Avatar
New User
If not mistaken... Gas weighs a little less then water does per gallon, thats something like 7+lbs, I go by a 8 pds myself. So having that much gas, would start pulling it down. I can tell by how much gas is in mine, just by the feel too...
dicecivic94
Dec 31, 2012 06:21 AM
spookum
Jan 31, 2011 04:32 PM
F23Coupe
Aug 6, 2007 11:15 AM
dizzyroc88
25
Dec 2, 2006 05:13 AM
TealCivic93
Apr 8, 2006 09:31 AM
