HELP!!!! Radiator Problems!!!!!
Old Jan 16, 2003 | 07:23 PM
N1NjA TuRtLE's Avatar
Default HELP!!!! Radiator Problems!!!!!
I just resently put in a tank of coolant in my radiator tank two days ago (Tuesday) all of a sudden i checked my radiator tank today, it was down to min. So i was like WTF?!?!?!?! and it was all over my outside the tank and on top of the radiator fan and so i wanna know why does it do this? it's a 92 CX HB
Old Jan 16, 2003 | 08:03 PM
youngkow's Avatar
Default Re: HELP!!!! Radiator Problems!!!!! (YellowSpoonEG6)
It must be leaking. Have the engine running, and see if you can see where it's leaking from.
Old Jan 16, 2003 | 08:07 PM
pennies_hatchie's Avatar
Default Re: HELP!!!! Radiator Problems!!!!! (youngkow)
buy a new a radiator
Old Jan 16, 2003 | 08:30 PM
Default Re: HELP!!!! Radiator Problems!!!!! (pennies_hatchie)
Is that really necessary?
Old Jan 16, 2003 | 08:34 PM
lo_95EJ's Avatar
i just recently had the exact same problem...id drive and after id notice the ground all wet and **** so i checked the rad and it was coming out all over the place...i had no choice but to buy a new rad.
Old Jan 16, 2003 | 08:38 PM
Default Re: HELP!!!! Radiator Problems!!!!! (lo_95EJ)
Serious, damn this is bs!!
Old Jan 16, 2003 | 08:44 PM
IWearMyKswiss's Avatar
New User
check to see if you could find the leak first,..dont just go and buy a radiator just yet,...whats your temp gauge say when your car is on for awhile???
Old Jan 16, 2003 | 08:48 PM
Default Re: HELP!!!! Radiator Problems!!!!! (WiDeBoDyEK)
i believe they also have those radiator leak liquids where it can seal the leaks if they're small enough. just go to wal-mart, either that or like i said, buy a new one.
Old Jan 16, 2003 | 08:50 PM
My temp gauge is normal like it always is......
Old Jan 16, 2003 | 09:45 PM
any other suggestions?
Old Jan 16, 2003 | 09:57 PM
KF_S2000's Avatar
What other solutions do you think there could be? You lost a whole jug of coolant in two days. If there's a HOLE in the radiator, what do you think needs to be done about it? Come on man.
Old Jan 16, 2003 | 10:03 PM
New User
Default Re: HELP!!!! Radiator Problems!!!!! (kf_Type-R)
if theres a hole in the radiator,..then buy a new radiator,..should run you about 100 bucks,..check for leaks in the hoses though..check reall good,..buying hoses is way cheaper then buying a new radiator
Old Jan 17, 2003 | 02:08 PM
Damn when i turn on my engine i don't see any leaks anywhere.... so i don't know what's going on...... damn
Old Jan 17, 2003 | 05:47 PM
all stock's Avatar
do u know if the radiator has ever been changed before? from the accounts of friends i know, and myself, usually the radiator seems to go out after about 10 years.
Old Jan 17, 2003 | 05:50 PM
tominos's Avatar
Default Re: HELP!!!! Radiator Problems!!!!! (edrop27)
check your rad. cap. warm it up and see if it leaks.
Old Jan 17, 2003 | 06:43 PM
owen_the_soyboy's Avatar
Default Re: HELP!!!! Radiator Problems!!!!! (tominos)
yes, especially if you see coolant on top of the radiator after you just cleanded it off 10 mins earlier!
abiliojr
May 30, 2015 05:23 PM
sdinteg
Jun 1, 2010 11:26 PM
^LORTA^RACING
May 11, 2007 11:47 AM
kingpen
Nov 7, 2002 03:57 PM
EGh22aEG
Jan 9, 2002 06:37 PM
