HELP!!!! Radiator Problems!!!!!
I just resently put in a tank of coolant in my radiator tank two days ago (Tuesday) all of a sudden i checked my radiator tank today, it was down to min. So i was like WTF?!?!?!?! and it was all over my outside the tank and on top of the radiator fan and so i wanna know why does it do this? it's a 92 CX HB
Re: HELP!!!! Radiator Problems!!!!! (YellowSpoonEG6)
i just recently had the exact same problem...id drive and after id notice the ground all wet and **** so i checked the rad and it was coming out all over the place...i had no choice but to buy a new rad.
Re: HELP!!!! Radiator Problems!!!!! (lo_95EJ)
check to see if you could find the leak first,..dont just go and buy a radiator just yet,...whats your temp gauge say when your car is on for awhile???
Re: HELP!!!! Radiator Problems!!!!! (WiDeBoDyEK)
i believe they also have those radiator leak liquids where it can seal the leaks if they're small enough. just go to wal-mart, either that or like i said, buy a new one.
any other suggestions?
Re: HELP!!!! Radiator Problems!!!!! (kf_Type-R)
if theres a hole in the radiator,..then buy a new radiator,..should run you about 100 bucks,..check for leaks in the hoses though..check reall good,..buying hoses is way cheaper then buying a new radiator
do u know if the radiator has ever been changed before? from the accounts of friends i know, and myself, usually the radiator seems to go out after about 10 years.
Re: HELP!!!! Radiator Problems!!!!! (tominos)
check your rad. cap. warm it up and see if it leaks.
