cc DSM Injectors on an 89 Si
Old Jan 16, 2003 | 06:25 PM
dan89crxsi's Avatar
Default cc DSM Injectors on an 89 Si
Would 450cc DSM Injectors from a 90 Laser Turbo fit a D16a6???
Old Jan 16, 2003 | 06:32 PM
sic2kSi's Avatar
Default Re: cc DSM Injectors on an 89 Si (dan89crxsi)
They should fit, I used to have some on my LS. But there really a bit much, I'd say get like 270cc, or 310cc, and if that doesn't cut it put the 450's on. (We took them off my Integra after only a few hours).
Old Jan 16, 2003 | 06:41 PM
dan89crxsi's Avatar
Default Re: cc DSM Injectors on an 89 Si (juz1badLS)
Im planning on running 10psi you dont think it would need them?
Old Jan 16, 2003 | 07:13 PM
kyle h.'s Avatar
i think you would need them for 10psi. also, you need to modify the lower seals (where they mount into your manifold)...or buy "special" ones. <---anyone that can answer that?
Old Jan 16, 2003 | 07:22 PM
rioninja's Avatar
They plug right up to the stock injector clips, and fit into the fuel rail fine. The rubber grommets in the intake manifold need to be modified though, like was said. You can use a dremel, and just enlarge the inside of the grommets a bit until it fits snug. I dont have any pics handy, or i'd show you mine. What kind of setup do you plan on using for fuel? your definatly going to need 450s for 10psi.
Old Jan 17, 2003 | 02:33 PM
dan89crxsi's Avatar
Default Re: cc DSM Injectors on an 89 Si (RioNinja)
I dont know about the fuel setup yet I am trying to plan it out myself but I am learning as I go.
(BTW) How much for the seats?
Old Jan 17, 2003 | 02:46 PM
rioninja's Avatar
250 picked up. Fabric is perfect, the foam is slightly thin in the drivers side bolster. Easy to unclip the cover, and redo it.
AJxr
13
Dec 26, 2005 07:21 AM
ALMXDUPINTEGRA
May 29, 2005 11:18 PM
4rcefeddeceiver
Jan 6, 2004 05:23 PM
flat-blk-HB
Jul 9, 2002 10:09 AM
paulzy
Sep 3, 2001 12:18 PM
