What are the symptoms of a blown head gasket?
Old Jan 16, 2003 | 03:39 PM
canuck-mx6's Avatar
Default What are the symptoms of a blown head gasket?
When you remove the oil cap while the engine is running do you get air coming out? If you do, what could the cause be? Blown headgasket, worn vavle seals, or even a stuck valve?
Old Jan 16, 2003 | 03:40 PM
Bbasso's Avatar
Default Re: What are the symptoms of a blown head gasket? (canuck-mx6)
Milk shake.
Old Jan 16, 2003 | 03:41 PM
Bbasso's Avatar
Milk shake.
D'OH!
I just read your post again and from what I remember 99.9% of cars blow air...
Old Jan 16, 2003 | 03:45 PM
canuck-mx6's Avatar
Default Re: What are the symptoms of a blown head gasket? (Bbasso)
Milk shake.
Well what if the oil is not milky or the coolant does not overflow into the overflow bottle? Does that mean that the air through the oilcap is caused by another problem?
Old Jan 16, 2003 | 03:52 PM
uNF$@#!'s Avatar
mine blows too
accord94cd7
May 27, 2013 04:25 PM
ericstambaugh07
Jun 25, 2007 09:08 AM
luis666
Jun 21, 2006 01:52 PM
FastNFurious
May 20, 2003 04:29 PM
