possible to use a smaller fuel nozzle to lean out no2 mix?
Old Jan 16, 2003 | 02:41 PM
MikeMAN's Avatar
Default possible to use a smaller fuel nozzle to lean out no2 mix?
i am running a 75 shot zex, with ZEX plugs, 93 octane w/a can of octane booster, stock timing. I pulled my old Denso stock plugs today and found they were black and I assume that its because my b16a2 swap was installed with a GSR ecu. So could I used a smaller fuel pin for the 75 shot such as a 34/36 instead of a 32. lemme know!
thanks,
mike
Old Jan 16, 2003 | 06:23 PM
Shawn C's Avatar
In The Garage
Default Re: possible to use a smaller fuel nozzle to lean out no2 mix? (MikeMAN)
you could, but i dont know if i would. the B16A has the same injectors (270cc) and fuel pump (135 lph) as a gs-r, so i would imagine the fuel maps are similar. and especially on a dry kit, such as the zex, if you lean out the fuel mixture, youre gonna detonate, and burn up some exhaust valves. but its your baby.
Old Jan 16, 2003 | 07:57 PM
MikeMAN's Avatar
Default Re: possible to use a smaller fuel nozzle to lean out no2 mix? (22lbGS-R)
yea, i also figure, more nitrous isn't good without more fuel..
so i left it
95greenlude
May 2, 2007 02:02 PM
BLU BY U
Honda Civic (2006 - 2015)
Nov 6, 2006 03:50 PM
1INTEGRA
Feb 23, 2004 01:21 PM
Smoochy
Feb 17, 2003 12:59 PM
xxplosif1
Apr 21, 2002 07:06 AM
