crank angle sensor
Old Jan 16, 2003 | 12:18 PM
chet's Avatar
Default crank angle sensor
i'm getting this code, and i'm pretty sure this has something to do with my distributor. should i just replace the entire distributor (was purchased new from honda a year ago) or is there something else i should try first.
electrical problems are something i'm not good at...any suggestions would be great.
i have an obd1 b16a3 in a 92dx hatchback. all new spark plug wires, wiring is otherwise fine, vtec activates, car went 14.5@95 with no other modifications.
thanks, chet
[Modified by chet, 9:19 PM 1/16/2003]
Old Jan 16, 2003 | 12:32 PM
Kataku2K3's Avatar
Default Re: crank angle sensor (chet)
Your CKP shouldn't go out that fast... I would check the wiring but I don't really know what would go wrong there... Everything for your swap was just plug n play but I would check to see that there are no breaks in the wire and that all your connectors are tight... If everything checks out good there then maybe you do have something wrong with the distributor... If so try just replacing the CKP if you have one laying around... Good Luck
Old Apr 19, 2003 | 12:07 PM
gupta_p's Avatar
do you know wher ehte CKP sensor is lockated in a 92 cx hatchback?
I can't seem to find it ..
Jtkdirtbike
Sep 7, 2013 06:47 PM
hondaaccordf23
Nov 18, 2012 08:56 PM
raidacaipo
May 18, 2009 08:57 AM
spoonhatchblack
Mar 17, 2004 10:17 AM
89 CRX SI
27
Jan 20, 2003 04:12 PM
