Ordering Custom JEs, need the following info on my B16!!
Old Jan 16, 2003 | 07:25 AM
Mr. Vapor's Avatar
Default Ordering Custom JEs, need the following info on my B16!!
Stock b16, stock crank, stock head. Sleeved to 83mm
need the following specs for the b16!
Cubic Inch displacement: Im assuming 1600cc?
bore size: Stock is 81mm but im bored to 83mm
stroke: ?
Rod Length: ?
Rod Small end width: ?
thickness above pin: ?
block height: ? (its stock)
deck clearance: ? (Stock)
compression height? (If known)
head gasket thickness: ? (Stock thickness)
Camshaft specs:
Gross Valve Lift Intake: ?
Gross Valve Lift exhaust: ?
Lobe seperation (Degrees): ?
Degreed in Std Degree + : ?
Degreed in Std Degree - : ?
Duration @ .050 Intake: ?
Duration @ .050 exhaust: ?
Valve lift at TDC Intake: ?
Valve lift at TDC Exhuast: ?
Combustion Chamber size in CCs
Valive diameter Intake
valve diameter exhaust
again, if anyone can point me in the right direction, id be greatly indebted to you, any informatin will help very much.
Old Jan 16, 2003 | 10:11 AM
paulzy's Avatar
Default Re: Ordering Custom JEs, need the following info on my B16!! (NYb16)
funny...when I ordered my JE pistons, they never asked for that stuff...
I jsut said I needed some pistons for a sotck bore ls/vtec(b16 head)and what compression I wanted
Harleyraff
Mar 1, 2013 01:51 PM
96halx
Jul 25, 2009 11:09 AM
freezerburnv2
Mar 12, 2004 12:45 PM
Mr. Vapor
Jan 16, 2003 09:34 PM
Evs-One
Jul 29, 2002 06:03 PM
