Greddy Intercooler Type 24(larger)
Old Jan 16, 2003 | 07:03 AM
kidaniel's Avatar
Default Greddy Intercooler Type 24(larger)
Do you you think that the type 24 intercooler will fit in the OEM bumper? Could i just moddify the bumper? Also, do you think that it will fit with the Mugen front bumper? Thanks!
Old Jan 16, 2003 | 07:27 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Greddy Intercooler Type 24(larger) (kidaniel)
you will have to remove your crash bar to fit that intercooler
Old Jan 16, 2003 | 08:01 AM
Firedrake's Avatar
Default Re: Greddy Intercooler Type 24(larger) (Boosted97Lude)
Yeah, like he said, you'll have to either remove or cut the heck out of the front crash support bar thingie to fit that IC.....it's like 11 inches high or something.....I could only fit my 8 inch high IC by cutting a little off the bottom of the support
Brian
Old Jan 16, 2003 | 08:05 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Greddy Intercooler Type 24(larger) (Firedrake)
no, no, if he wants to use a stock bumper he WILL have to remove the bumper support. i cut the hell out of mine, and i have a body kit that hangs like 2-2.5" below the stock location, and the bitch STILL barely stays hidden
Old Jan 16, 2003 | 08:13 AM
kidaniel's Avatar
Would the front bumper be durable enough to withstand a minor impact with out damaging the intercooler? .Does anyone know of an aftermarket front bumper that will fit with the intercooler and doesn't look ricey? Because I'm afraid if i get in a little wreck my intercooler is pretty much screwed and i want a bumper thats oretty durable.
Thank you
Old Jan 16, 2003 | 08:15 AM
kidaniel's Avatar
Would the front bumper be durable enough to withstand a minor impact without damaging the intercooler? Does anyone know of an aftermarket front bumper that will fit with the intercooler and doesn't look ricey? Because I'm afraid if i get in a little wreck my intercooler, then the intercooler is pretty much screwed and i want a bumper thats pretty durable.
Thank you
Old Jan 17, 2003 | 09:30 AM
Firedrake's Avatar
How minor an impact? If you bump something at like 5 mph you should be fine, you'll just mess your bumper but not the IC......
Brian
Old Jan 17, 2003 | 09:32 AM
Boostless97Lude
Guest
Posts: n/a
it's fit's behind mine pretty good, but i had to cut abouy half the crash bar off the bottom, so, anykind that is like a bodykit w/lower ground effects should work ok
GSROWNSU
Jan 7, 2008 05:16 PM
integranator
Feb 11, 2007 09:31 AM
illestrolla247
Dec 28, 2004 02:19 PM
TodaTeg
Jul 5, 2003 09:29 PM
Andrew 825SM
Jul 3, 2002 04:00 PM
