D16 VTEC oil pump in a NON VTEC D16
Old Jan 15, 2003 | 09:11 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default D16 VTEC oil pump in a NON VTEC D16
curious as to if a Y8/Z6 oil pump would fit in an A6 engine. they have almost twice the volume of the non VTEC pump.
anyone heard of it being done? i got my A6 on the stand and rebuilding, need to know if i should opt for the bigger pump
thanks
stan
Old Jan 16, 2003 | 07:24 PM
Default Re: D16 VTEC oil pump in a NON VTEC D16 (90crxsi)
i need to know this guys.
stan
Old Jan 20, 2003 | 12:04 PM
GapxGuy's Avatar
Sushi Buffet Champion
I would also like to know. Is there a difference in the Y7 and Y8 oil pumps? Are vtec and non-vtec oil pumps different for single cams?
Old Jan 20, 2003 | 12:25 PM
Default Re: D16 VTEC oil pump in a NON VTEC D16 (GapxGuy)
imma keep this on the top for now,
the Y8/Z6 VTEC pump flows almost twice the amount to the D16A6 pump, and since i am rebuilding my spare A6 having more oil is always better.
stan
Old Jan 20, 2003 | 01:26 PM
GapxGuy's Avatar
Guess what I just found out? The A6 and Z6 oil pumps are the same. The part numbers are identical. So the 88-95 CRX/Civics have the same oil pumps (except for the CX). The Y7 and Y8's have the same oil pumps.
Old Jan 20, 2003 | 01:31 PM
GapxGuy's Avatar
So the Y7 and Y8 have the same oil pumps but they're different from the 88-95 CRX/Civic oil pumps...don't know which is better, I'm guessing the Y7 + Y8's are have better flow.
So in conclusion, D-series vtec and non-vtec have the same flowing oil pumps oppose to the B-series which makes a difference between vtec and non-vtec oil pumps.
Anyone feel free to correct me if I'm wrong.
Old Jan 20, 2003 | 04:29 PM
you are correct.
hereis the info on the D series. My original thought was to use the Y7/Y8 pump on an A6.
that would solve all my oil starvation problems.
stan
94EG8
10
Jan 19, 2014 02:29 PM
Chris_Spires
Aug 13, 2009 10:33 AM
nw13
May 5, 2008 05:10 PM
Nichelson_Performance
Apr 25, 2008 04:41 PM
