How can I tell if my car is wired for VTEC???
Old Jan 15, 2003 | 07:47 PM
AndyD's Avatar
Default How can I tell if my car is wired for VTEC???
Hey guys, I have a 1992 Prelude Si 4 Wheel Steering and I am going to be putting an H22 swap into it SOON!!! I was wondering how I can check to see if my 92 Lude is pre-wired for VTEC.
Are there any 92 Lude owners out there that was actually already wired for VTEC???
ASny help is greatly appreciated.
Old Jan 15, 2003 | 08:07 PM
papa_smurf's Avatar
Default Re: How can I tell if my car is wired for VTEC??? (AndyD)
no usdm 92 preludes Si's were wired for VTEC, some 93 Si's were and all 94 on preludes were. i have a 92 and had to wire it when i swapped in my h22a4, its no big deal really, not worth stressing over.
Old Jan 15, 2003 | 08:29 PM
Honda318dx's Avatar
What?? What do you mean wired for VTEC? Do you mean to ask is that is your wiring harness setup to support an H22a motor, no, its not...
Old Jan 15, 2003 | 09:46 PM
red92s's Avatar
Default Re: How can I tell if my car is wired for VTEC??? (Honda318dx)
Actually, I think some 4th gens were factory wired for VTEC, even though they were not equipped with the H22. I have heard numerous reports of this (from people who have found their car to be wired), but no one can nail down the specific years or trim levels that were so wired. A preludeonline.com member actually sent me a picture of the wiring (essentialy just a connector coming from the in-car harness, with nothing connected to it) in hopes that we could add it to the FAQ. I feel like an ***, 'cause now I can't find the pic
Old Jan 15, 2003 | 09:47 PM
Quiklude's Avatar
Default Re: How can I tell if my car is wired for VTEC??? (red92s)
i wouldnt bet on it though, not a big worry anyways, just 3 wires
goodluck
Old Jan 15, 2003 | 09:48 PM
CHK4TIX's Avatar
what? how is it now, I used my stock harness and i have not CEL's and not problems at all. Why do you say it not set up for a H22?
Old Jan 16, 2003 | 05:01 AM
humtake's Avatar
Default Re: How can I tell if my car is wired for VTEC??? (papa_smurf)
papa, did you do the extra 3 wires for the vtec? i have the helms electrical manual the shop manual and they do not stress anything about 3 extra wires, they go in to great detail about the whole system.
what three wires do i need to add and where do they need to go? im almost at the point where the swap is done and i just have to start crimping wires together. thanks for any help you could give.
Old Jan 16, 2003 | 07:39 AM
papa_smurf's Avatar
Default Re: How can I tell if my car is wired for VTEC??? (humtake)
actually it is two wires, one for your Vtec solenoid, and one to your vtec pressure switch, there is technically another wire but i don't count it because it is a ground for the vtec pressure switch and i jsut got a 5" piece of wire and made a connection to the chassis. much easier than running it to the ecu through the firewall like some have said, and works perfectly. um yea what did you want to know again? i thin the pinouts are A6 and D4 for the ones you need but its been a while, somebody check on that.
Old Jan 16, 2003 | 08:19 AM
red92s's Avatar
Coutsey of preludeonline.com:
Swapping an H22 into an h23-equipped car, you will need to add:
-VTEC solenoid, (signal=Green/Yellow to ECU Pin A4 )
-VTEC pressure (oil pressure), (signal=Lt blue to ECU Pin D6 )
-VTEC pressure (oil pressure), (ground=Black/Red )
Swapping an H22 into an f22-equipped car, you will need to add:
The wires listed above AND. . .
-Knock sensor, (signal=Red/Blue to ECU Pin D3)
-IAB, (signal=Pink to ECU pin Pin A17 ), (power=Blk/Yellow to 12v+ switched power source (hot with key in "on" or "start")
Old Apr 3, 2006 | 06:28 PM
AnthonyG2003
Guest
Posts: n/a
Can anyone answer this for me really quick??
Old Apr 3, 2006 | 06:59 PM
petern101's Avatar
Default Re: How can I tell if my car is wired for VTEC??? (AnthonyG2003)
my 94 bb4 was NOT setup for vtec, had to be wired in
so to answer any and all questions
NO VTEC WIRING IN SI'S, if you find out it is, well you sir should buy a lottery ticket
Old Apr 3, 2006 | 07:01 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: How can I tell if my car is wired for VTEC??? (petern101)
looking at some of the other related threads...I am wired for vtec...
Old Apr 3, 2006 | 07:03 PM
95greenlude's Avatar
b.s. my car is wired for vtec...95 SE
Old Apr 3, 2006 | 07:04 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: How can I tell if my car is wired for VTEC??? (95greenlude)
the more i look, the more it looks like i have the wiring too....i have a 93 si
Old Apr 3, 2006 | 07:19 PM
green/yellow=vtec solenoid taken 3 minutes ago
Old Apr 3, 2006 | 07:22 PM
AnthonyG2003
Guest
Posts: n/a
where do you find that at?
Old Apr 3, 2006 | 07:24 PM
SteveoBA8's Avatar
Old Apr 3, 2006 | 07:25 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: How can I tell if my car is wired for VTEC??? (SteveoBA8)
imma go look for that really quick....
Old Apr 3, 2006 | 07:27 PM
AnthonyG2003
Guest
Posts: n/a
Yup, I have that...So wiring VTEC is going to be really easy?
Old Apr 3, 2006 | 07:28 PM
jdmnash's Avatar
94 SI here. "Not pre-wired"
Old Apr 3, 2006 | 07:37 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (apeng09)
So, If I dont search...I get bitched at, and If I post in a thread from 3 years ago...SHOWING THAT I SEARCHED I get bitched at? Or are you just stating that this thread is 3 years old?
Im confused.....
Old Apr 3, 2006 | 07:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apeng09 &raquo;</TD></TR><TR><TD CLASS="quote">way to bring back a 3 year old post</TD></TR></TABLE>
rather him bring back old stuff, than post more
Old Apr 3, 2006 | 07:44 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (95greenlude)
Thats what I thought the purpose of the searching is....
Old Apr 3, 2006 | 08:16 PM
Saosinx's Avatar
Default Re: (AnthonyG2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">Thats what I thought the purpose of the searching is....</TD></TR></TABLE>
ellywyte
Mar 30, 2011 02:28 PM
LIBBIE1
Aug 11, 2009 10:29 AM
.Ryan
Nov 4, 2005 03:30 AM
92-LS-Civic
Jun 11, 2004 11:57 PM
Soda Popinski
Feb 25, 2004 06:50 PM
