ok n00b questions
Old Jan 15, 2003 | 06:57 PM
Phire's Avatar
Default Few Gasket and Side Mirror ?'s
ok I got a few questions... After all the help you guys gave on changing my valve cover gasket, I had to ask these!
Whats this? [found in trunk]
ok when I replaced the valve gasket cover, I had these left over
Now I suspect they are valve seals, but I didnt replace the ones in there due to it not being necessary???
one more to go......
Is this a common problem? it happened to the driver's side also, so previous owner spray painted it [:cries:]
Thanks in Advance!
Derek
[Modified by Phire, 3:57 AM 1/16/2003]
[Modified by Phire, 5:13 AM 1/17/2003]
Old Jan 15, 2003 | 07:15 PM
Steve04SVT's Avatar
Default Re: ok n00b questions (Phire)
Not sure about the thing at the top, but the four seals seem to be spark plug cylinder seals, unless you replaced those also. If so, then I have no idea. Now the mirror problem. If you are referring to the peeling of the paint, then it must be somewhat of a common problem. My mirrors on my '96 Accord have a spot around the curve on the mirror, just where it meets the triangular part of the mirror, where the paint peeled off awhile back.
Old Jan 15, 2003 | 07:33 PM
jspark79's Avatar
Aw man that mirror crap is messed up. Such a shame to do to a genuine Honda part. Someone needs to take care of that s*it.
About those rings I wish I knew
One2chi's Avatar
Default Re: ok n00b questions (Steve96Accord)
no idea....on anything....but welcome to h-t that top thing looks liek it might be some kidn of moulding....any moulding missing on the car anywhere? maybe it goes somehwere in the trunk...i dunno...sorry
Old Jan 15, 2003 | 07:35 PM
Phire's Avatar
well, I had 4 new seals but the old ones didnt seem like they needed replacing, so I didnt bother....as far as the mirrors, I suspected it was a common problem....I still am mystified as to what that plastic thing is I found....
Old Jan 15, 2003 | 07:45 PM
RaceTilIDie's Avatar
Those four seals usually only leak if the top nuts w/ rubber around are crushed/cracked. THe rubber on those cap nuts is what holds the valve cover tightly against the head. THe top pic is a piece that slides over sheet metal to give it a finished look and protect from sharp edges. Look around for sharp edge that looks like it fits.
Old Jan 15, 2003 | 08:15 PM
Phire's Avatar
Default Re: ok n00b questions (RaceTilIDie)
ok sweet. yea some shop quoted me like $85 for replacing the seal...pfff
Old Jan 16, 2003 | 03:23 AM
urbanlegend21's Avatar
New User
that is a mandatory 1 hour rate they charge for all work probably
Old Jan 16, 2003 | 05:01 AM
Nick M's Avatar
Default Re: ok n00b questions (urbanlegend21)
Here is a recommendation from your sometimes not so friendly moderator.
Name your thread with something other than "I need help" or "n00b questions".
The search function relies on thread titles, so when you search for "gaskets and seals" this thread wont come up.
Old Jan 16, 2003 | 07:09 PM
cyrixvsp2's Avatar
Default Re: ok n00b questions (Nick M)
that first thing looks like it would be a rail for one of the windows, like drivers or passenger window rail.....other than that, i have no idea.
Just me
Dec 20, 2008 04:16 PM
RaceMyGhost
Jul 7, 2006 11:03 AM
g3teg97
Mar 27, 2006 10:27 AM
CalvitoSol
Jul 8, 2002 12:03 AM
