Cluster fawked - or my car is... ?
Old Jan 15, 2003 | 05:31 PM
sparq's Avatar
Default Cluster fawked - or my car is... ?
Ok, yet again I want to throw this out there for anyone who might have had the same problems. I have a 1992 DX sedan, and I was installing a non USDM 5th gen cluster (w/ tach) and when I turn the key to ACC - the needles jump. Tach to like 1k rpm and the cluster one goes up the same amount (height wise)
Whats going on? For some reason is the DX weird and I need to do something other then plug it in - or because my car isnt "JDM y0!" do I need to throw like a resistor/capacitor on anything? Since BOTH do the same thing im assuming its not the cluster. I pulled it all apart and gave it a complete clean up (incase some lube was causing a bad ground or something) but no dice. Any way I can test this bad boy or get it working properly? Anyone got some advice?
If it is busted, how would I go about getting it repaired?
Old Jan 15, 2003 | 05:34 PM
sparq's Avatar
Default Re: Cluster fawked - or my car is... ? (sparq)
Also, could someone tell me what wires control the speedo / tach and maybe I can trace them down on the back of the cluster and see whats up. Do it like this...
Looking at the cluster - rotate it 180, and then the TOP wire is #1, below that #2 and so on. Same with the right side... maybe im missing what im looking for ??
Old Jan 18, 2003 | 03:13 PM
sparq's Avatar
... anyone ... ?
Supa Troopa
62
Jul 19, 2023 10:07 AM
V.MoMO
Sep 12, 2010 08:44 AM
static-x
Aug 14, 2008 08:07 AM
JDM manc 10
15
Sep 20, 2006 11:14 AM
Frito-Ray
Feb 15, 2005 12:12 AM
