d16y8 IM on an a6???
Old Jan 15, 2003 | 05:11 PM
Red_Si's Avatar
Default d16y8 IM on an a6???
ok i bought a d16y8 head a couple weeks ago. i'm not sure if it was from an automatic or manual tranny car, how do i figure which one it is??? i'm going to be using the y8 head when i put it all on and my car is an manual tranny, so i need a manual tranny IM right??? I was planning on using either a bored out LS tb or a b16 tb if that makes any difference??? thx for the help ahead of time!
Old Jan 15, 2003 | 05:16 PM
altoid's Avatar
Default Re: d16y8 IM on an a6??? (Red_Si)
either or...i just saw a post awhile ago on how you'd have to mod the auto one, but its not that difficult
Old Jan 16, 2003 | 03:23 PM
Red_Si's Avatar
how do i check and see if it's either automatic or manual??? what are the differences??? thx guys
Old Jan 16, 2003 | 04:50 PM
4drEF's Avatar
Keyboard Humorist
The only major difference is that the IAC is mounted on the back of the intake manifold on the manual trannied one and the IAC is built onto the TB on the auto. I think there is also a spare vacuum port on the auto one.
You should be able to use either manifold with matching TB as a swap donor unless the IAC and map sensor plugs are different.
Old Jan 16, 2003 | 05:20 PM
solorex's Avatar
Default Re: d16y8 IM on an a6??? (4drEF)
Nope. The EACV which is mounted on the throttle body of the auto does not work because it is a 3-wire sensor instead of a 2-wire. Either get the manual y8 manifold or drill holes in the back of the auto manifold so that you can bolt on a EACV. Just de done with it and make sure you get one off a 5-spd, it's way less hassle.
[Modified by solorex, 2:21 AM 1/17/2003]
Old Jan 16, 2003 | 07:13 PM
Red_Si's Avatar
Default Re: d16y8 IM on an a6??? (solorex)
well it didn't come with a tb thats why i was getting an ls or b16 one. there is like a little black cylindric shape, is that an eacv or whatever??? that's the only sensor thing that i see. do i have a manual tranny one or auto?
Old Jan 17, 2003 | 06:11 PM
Red_Si's Avatar
help!!!
alacard
Dec 25, 2006 11:30 PM
masterexpert
May 31, 2005 04:13 AM
J Rob
May 15, 2005 06:42 AM
Snail Tuning
Oct 8, 2003 06:24 PM
RSZero1
26
Apr 24, 2003 07:12 PM
