manual/auto y8 intake mani difference?
is there a difference in the manual and auto d16y8 intake manifolds? if there is, can a manual mani be used on an auto? i remember reading something about this a while back, but i cant seem to find info on it now...thanks in advance.
Re: manual/auto y8 intake mani difference? (alacard)
Auto uses a 3-wire iacv under the throttle body. Manual uses a 2-wire iacv at the back of the manifold. Yes you can use the manual manifold as an auto manifold. All you need to do is leave the 2-wire iacv at the back of the manifold unplugged of it's coolant hoses and electrical plug, but still bolted on. Then you need to run a throttle body with a 3-wire iacv.
got it...so the auto d16y8's came with the same throttle body and iacv as the y7's? interesting...thanks for the info, i just sold a manual intake mani to a kid with an auto...wanted to make sure it would work
codyellis
10-16-2010 01:01 PM
Mikes2000civicsi
02-24-2010 11:56 AM
dw.VTEC
04-08-2005 03:59 PM
Si-Yaaa!
12
01-15-2003 01:07 PM
