KYB Shocks Install Problem
Old Jan 15, 2003 | 05:06 PM
swrdply400mrelay's Avatar
Default KYB Shocks Install Problem
I installed a set of KYB AGX adjustable shocks on my 00 Civic last night, and now when I drive around, I hear clunking sounds from the front struts. Anyone have any idea what it could be? I've re-checked and tightened all the bolts and nuts but can't seem to get rid of the sound. TIA
Old Jan 15, 2003 | 06:36 PM
qcoffey's Avatar
Default Re: KYB Shocks Install Problem (swrdply400mrelay)
Did you check to see if you reinstalled the upper shock bushings correctly?
Old Jan 15, 2003 | 07:06 PM
Default Re: KYB Shocks Install Problem (qcoffey)
I'm not exactly sure what that is, but I used the stock bump stop and trimmed it about an inch. Then installed a washer that holds in place about half way down the piston rod, then a stock blackrubber bushing, then the stock black plastic shock cover, then a black stock washer, then the black top of the strut. I was sure the springs were seated correctly in the shocks too and only the front makes the clunking noise.
Old Jan 16, 2003 | 07:07 AM
ttt
Old Jan 16, 2003 | 07:25 AM
Spade's Avatar
It's possible your struts are hitting your hood. if you didn't install them properly.
Old Jan 16, 2003 | 07:41 AM
Default Re: KYB Shocks Install Problem (Spade)
I thought so too, but I lifted the hood and shook the front of the car and still got the sound. Thanks for the suggestion though. Anyone else?
Old Jan 16, 2003 | 08:02 AM
Spade's Avatar
So with the car sitting and you rocking it you get the sound?
If so, the springs are not in the right way.
Old Jan 16, 2003 | 08:30 AM
Really? What do you mean because I can see the springs seat at the bottom of the shocks.
Old Jan 16, 2003 | 08:44 AM
slomofo's Avatar
GDD Member
Doesn't the stock black plastic cover go on before the stock black rubber bushing?
Old Jan 16, 2003 | 08:46 AM
Default Re: KYB Shocks Install Problem (slomofo)
can anyone confirm this?maybe this what is causing the noise? thanks
[Modified by swrdply400mrelay, 5:48 PM 1/16/2003]
Old Jan 16, 2003 | 08:52 AM
Spade's Avatar
Old Jan 17, 2003 | 08:54 AM
Civichatch2k's Avatar
Yep sounds like the springs are not seated in the perch.
Old Jan 17, 2003 | 10:52 AM
youngkow's Avatar
I had a similar problem, but it was part # 10 making the noise. I also had coilovers too. What i ended up doing is getting some huge heat shrink tubing, and cut it to size, and replace that. No more clunking or sqeaking. Are you using stock springs?
Old Jan 17, 2003 | 12:35 PM
Default Re: KYB Shocks Install Problem (youngkow)
Well I can see the springs seated from the wheel well, so I don't think that's the problem. I have Neuspeed Sport springs. From looking at the diagram, I think I put the bushing #6 underneath the shock cover instead of under the cap #7. I have time this Monday since it's MLK day so I'm gonna take it all apart, put the bushing in the right place, and re-check the seating of the springs. Thanks for all your inputs.
Old Jan 17, 2003 | 02:33 PM
HondaGSR's Avatar
If part #10's outside Diameter is larger than the inside diameter of the sping it can make that noise.
DcLs
Sep 19, 2008 07:54 PM
phoQ
Mar 22, 2005 03:21 AM
jArceo
Apr 27, 2004 04:43 PM
thehondaguru
Mar 22, 2004 07:05 PM
94cxHybrid
Mar 3, 2002 09:57 PM
