fuel injector code (WTF)
Old Jan 15, 2003 | 03:33 PM
4ghatch's Avatar
Default fuel injector code (WTF)
I need to know if anyone has a clue why my injector code is on again. I just had it on last week so i gut another injector to replace the maxed out other one could that be the problem again already?? in three day and a total of mabye 30 miles since the fix?
Old Jan 15, 2003 | 03:56 PM
Sonny's Avatar
Default Re: fuel injector code (4ghatch)
It's most likely a wiring problem.
What ECU are you using and what injectors?
Sonny
Old Jan 15, 2003 | 06:34 PM
4ghatch's Avatar
Default Re: fuel injector code (Sonny)
Sonny
My car is fully stock right now. So whatever the 91 dx hatch has
Old Jan 16, 2003 | 12:04 AM
b19coupe's Avatar
Dual point injection sucks, sorry. Check the green connector near the left shock tower, seen a couple of code #16's turn out to be a bad connection there.
Old Jan 16, 2003 | 11:22 AM
Perfectionist's Avatar
The ECU will throw a code 16 when there is a break in the electrical path for the injectors. This path includes ignition switch, main relay, injector resistors, injector coils, and all the wires and connectors in between. Happy hunting.
(Have you replaced or resoldered your main relay since you had the car?)
Old Jan 16, 2003 | 02:33 PM
Chiovnidca's Avatar
Did you check the resistances of them? I posted the specs in one of your other threads.
ExtraBlackRex
Oct 28, 2010 05:18 PM
Red_ED8
Jul 15, 2010 11:19 AM
square_1
Apr 3, 2007 01:46 PM
93cavRS
11
Oct 11, 2006 01:25 PM
delux247
Jan 28, 2004 11:48 AM
