HELP!!!! Why wont my car start!?!?!?!!?
Old Jan 15, 2003 | 03:18 PM
vtec69's Avatar
Default HELP!!!! Why wont my car start!?!?!?!!?
I just changed the seals behind the cam gears cause they were leaking. I had to remove the starter and loosen the alt belt to do this cause i also had to take the crank pulley off so i could set the timing properly. I didnt take the cams out to do this and didnt remove anything with wires beside the battery.
I went to start it up and it sounds like the battery is dead but its showing a charge on my charger. It wont turn over at all and the lights and the radio work but it sounds like the battery is dead
Can anyone help????
TIA
-Brian
Old Jan 15, 2003 | 04:15 PM
Briman2021's Avatar
Default Re: HELP!!!! Why wont my car start!?!?!?!!? (vtec69)
Well, make sure you try the easiest solution first, it will save you a lot of hassle 9 times out of 10.
When my battery died, i could turn on the lights and stuff, but not enough juice to start it, so try jump starting it, or push starting it before you replace parts.
And remember the basic rule,
if the engine wont run, check for fuel, spark and air first.
[Modified by Briman2021, 5:18 PM 1/15/2003]
Old Jan 15, 2003 | 05:10 PM
abraunworth's Avatar
New User
Default Re: HELP!!!! Why wont my car start!?!?!?!!? (Briman2021)
Was the battery good before you changed the seals. WOuld it not start like right after you put it back together. Were you listening to the radio while working on it???
Old Jan 15, 2003 | 09:15 PM
samdawgsol's Avatar
New User
Default Re: HELP!!!! Why wont my car start!?!?!?!!? (abraunworth)
Make sure all the connections are secure, the battery and the starter.
Might as well and check the big 80 amp fuse under the hood.
Old Jan 15, 2003 | 09:17 PM
BackSideSA's Avatar
Default Re: HELP!!!! Why wont my car start!?!?!?!!? (samdawgsol)
try kicking it and yelling obscenities
that is what the mustang owner next door does every morning
Old Jan 15, 2003 | 11:49 PM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: HELP!!!! Why wont my car start!?!?!?!!? (HybridHackBatch)
ROFLMAO! Very droll!
Old Jan 16, 2003 | 05:33 AM
Soled Out's Avatar
Default Re: HELP!!!! Why wont my car start!?!?!?!!? (BlackDeuceCoupe)
Sounds like you didnt plug the wire back into the starter.
Old Jan 16, 2003 | 05:37 AM
nsxmatt's Avatar
Did you hook up the ground by the starter?
Old Jan 16, 2003 | 07:07 AM
vtec69's Avatar
Default Re: HELP!!!! Why wont my car start!?!?!?!!? (nsxmatt)
It turned out that the battery was very dry so i added some distilled water and charged it for 2 hours and when i went to start it it would only turn over if i gave it gas.
So i messed with the intake and throttle and got it to start
thanks for your help everyone
also BTW:
Is the t-belt suppose to wobble a little along the side by the exhaust manifold while the throttle is open?
swizz977
23
May 6, 2011 04:01 PM
xander1100
Oct 18, 2009 07:56 PM
vtec69
Jan 17, 2003 03:30 PM
vtec69
Jan 16, 2003 07:09 AM
