k24 swap
Old Jan 15, 2003 | 07:55 AM
REALLY banned
Guest
Posts: n/a
Default k24 swap
does anyone know if you can swap a k24 in for the k20 in a 03 Si
Old Jan 15, 2003 | 07:56 AM
Red94Sedan's Avatar
Default Re: k24 swap (banned)
Whats a K24 engine? Just curious. Never heard of that.
Old Jan 15, 2003 | 07:57 AM
REALLY banned
Guest
Posts: n/a
its in the 03 CRV / accord / element
Old Jan 15, 2003 | 07:58 AM
REALLY banned
Guest
Posts: n/a
i know that the b-series motors have the same block... i need to know if the k24 is the same size as k20
Old Jan 15, 2003 | 08:14 AM
liam821's Avatar
25 Year Member
The k24 is a bigger k20. Ive heard of people doing k24 blocks with the RSX typeS head. IE crvtec conversion. With the RSX head and the k24 block it should make for a very powerful motor.
The k24 should bolt up to the civic - although im not 100% sure. You should give hasport a call and ask - they would know for sure.
liam
Old Jan 15, 2003 | 09:45 AM
crs's Avatar
crs
Default Re: k24 swap (liam821)
my friends were telling me to swap my motor for a k20a2 or k24 and i have an 02 civic (theyre crazy educated with that ****) so im guessing it will fit in a si. while we're on the subject, can you do a b series swap into 02 civics?
Old Jan 15, 2003 | 09:49 AM
4g4me's Avatar
Default Re: k24 swap (crs)
hmmm. i am sure that there are no bolt in kits, but anything can be done with lots of money. I would probabally try to get a rsx-s engine if i were you.
Old Jan 15, 2003 | 10:13 AM
Spade's Avatar
Nope. Reason why is that the B series engines are 2001 and older.....if you put a 2001 engine in a 2002 chasis, it's illegal.
Hasport has swap kits for the K series into the 02 Civics.
Yes, the K24 is the same block as the K20. It like the previous generation B18 - B20 relationship is a larger bore and possibly stroke.
Old Jan 15, 2003 | 10:24 AM
CheezeFrog's Avatar
Default Re: k24 swap (Spade)
Don't the 7th gen Civics come with the old D-series motors, which have basically the same mount points as the B-series? Only the Si has the different mount points for the K-series motors.
Old Jan 15, 2003 | 10:25 AM
IM ALL BOB's Avatar
Default Re: k24 swap (CheezeFrog)
your correct cheesefrog.. and I would rather choice a k20 ITR motor..over the k24 any day..
Old Jan 15, 2003 | 10:27 AM
Spade's Avatar
Default Re: k24 swap (IM ALL BOB)
That's not the point though K20 ITR head on a K24 block
Old Jan 15, 2003 | 11:07 AM
SpooN Man's Avatar
I think hasport has the mounts for a "K" motor into a new civic platform (2k1 and up) in the works.
Old Jan 15, 2003 | 11:08 AM
oldB18EF's Avatar
The D17A2's mount points are not the same as a B's- otherwise youd see plenty of B series in 7th gens by now (2001 GSR/Type R's in 2k1 Civics)...you should see how many of these threads are created a day over at 7gcivic.com.
Can you do it? With the right amount of money.
Is it worth it? Nope.
Old Jan 15, 2003 | 11:54 AM
wizzards581's Avatar
Default Re: k24 swap (WR93EG)
why put rsx-s vtec head on to the crv k24 when it has vtec also?? mayb i would rather go wit the rsx-r...
vtec now = ivtec
Old Jan 15, 2003 | 12:37 PM
Spade's Avatar
Default Re: k24 swap (wizzards581)
vtec now = ivtec
Cams and valves are different and the ECU has a performance orintated programming not a workload/SUV programming.
Old Jan 15, 2003 | 12:51 PM
barto's Avatar
k24 is 2.4 liter and k20 is 2 liter
Old Jan 15, 2003 | 12:52 PM
E. Honda's Avatar
Default Re: k24 swap (EKHatchRacer)
More Torque, do it.
allmightykseries
Apr 9, 2009 07:41 PM
Toliyak47
Honda Civic (2006 - 2015)
18
Oct 27, 2007 11:26 AM
Syndacate
13
Dec 24, 2006 06:15 AM
Juniorhatch
May 26, 2006 07:15 AM
