2.4L swap?
Old 12-22-2006, 11:46 PM
Syndacate's Avatar
Default 2.4L swap?
I was thinking about swaps on the way down here and I was just wondering.
Why does nobody swap the element motors? People always taking the B20Z's outta the CRV's and slapping a VTEC head on it and calling it a day.
Why aren't people taking the 2.4L motors out of the elements and swapping them into civics?
Or is that the K24 I keep hearing about? Or is that outta the RSX Type-S or whatever the "super" RSX version was...?
<u>Please note:</u> I did absolutely <u>NO</u> research on this topic and telling me to search is as good as not posting at all because I don't particularly care. I'm just curious for somebody to fill me in here.
Old 12-22-2006, 11:59 PM
philosofy1's Avatar
Default Re: 2.4L swap? (Syndacate)
i'm not sure what motor comes with the element, but i believe the k24 is out of the tsx.
Old 12-23-2006, 12:08 AM
Pr0ject93hb's Avatar
Default Re: 2.4L swap? (philosofy1)
the element has a k24 as well
Old 12-23-2006, 12:10 AM
the element has a k24 as well. and a lot of people do swap them with a k20 tranny out of an rsx type s.
im thinkin about loosing the ls vtec and going k series...most likely the k24. but im not too sure yet.
i am pretty sure k24 is out of the element (tsx too i guess.)
Old 12-23-2006, 12:22 AM
philosofy1's Avatar
Default Re: 2.4L swap? (Pr0ject93hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0ject93hb &raquo;</TD></TR><TR><TD CLASS="quote">the element has a k24 as well. and a lot of people do swap them with a k20 tranny out of an rsx type s.
i am pretty sure k24 is out of the element (tsx too i guess.)</TD></TR></TABLE>
i know the k series motor is far more superior to the b series, but it just seems like too much money for one, not to mention the work it takes just to get it in the car and up and runnning.
the b series is just a straight bolt in, a plug n play!
Old 12-23-2006, 01:37 AM
97spooncivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
the b series is just a straight bolt in, a plug n play!</TD></TR></TABLE>
dont forget the problems about smogging and passing bar with a k, which i have yet to see been done legally. The only thing i have herd is turning it into a flex fuel vehicle, which seems like a pain
Old 12-23-2006, 02:48 AM
nighttrain33's Avatar
In short, yes the Element has a K24. It is different than the k24 in the TSX, though.
-Shane
Old 12-23-2006, 02:51 AM
From Wikipedia:
[edit] K24A1
Found in:
2002-2006 Honda CR-V
Displacement: 2354 cc
Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
Compression: 9.6:1
Power: 160 hp (119 kW) @ 6000 rpm
Torque: 162 ft·lbf (220 N·m) @ 3600 rpm
Redline: 6500 rpm
[edit] K24A2
Found in:
2004-2006 Acura TSX
Compression: 10.5:1
Power: 205 hp (149 kW) @ 6800 rpm
Torque: 166 ft·lbf (225 N·m) @ 4500 rpm
Redline: 7100 rpm
[edit] K24A3
Found in:
2003-2006 Honda Accord (Europe, Japan, and Australia)
Compression: 10.5:1
Power: 189 hp (140 kW) @ 6800 rpm
Torque: 164.5 ft·lbf (223 N·m) @ 4500 rpm
Redline: 7000 rpm
[edit] K24A4
Found in:
2003-2005 Honda Accord, 2003-2006 Honda Element
Compression: 9.7:1
Power: 160 hp (119 kW) @ 5500 rpm
Torque: 161 ft·lbf (218 N·m) @ 4500 rpm
Redline: 6500 rpm
[edit] K24A8
Found in:
2006/2007 Honda Accord
Compression: 9.7:1
Power: 166 hp (124 kW) @ 6000 RPM
Torque: 160 ft·lbf @ 4000 rpm
Redline: 6500 rpm
-Shane
Old 12-23-2006, 07:36 AM
6SPD_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
rsx (BASE) & '02-04 si comes with k20a3 rated at 160
02-04 usdm rsx-s comes with k20a2 rated at 200
05-06 rsx-s comes with 210 hp k20z1
'06+ si comes with 200 hp k20z3 (with new hp SAE ratings - which would equal 210 old #'s
Jdm ITR/CTR come with k20a 220hp
euro CTR comes with k20a2 (same as RSX-S 02-04)
my k20a (type R) in a ek back when I was partial tuned at 220 whp with open pipe
http://videos.streetfire.net/s...3.htm
vid is unedited & has boring partial throttle driving...in the middle is some good "out of car" footage
Old 12-23-2006, 07:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">i know the k series motor is far more superior to the b series, but it just seems like too much money for one, not to mention the work it takes just to get it in the car and up and runnning.
yea b series are the **** anyways, but my buddy just picked up a k20 w/ tranny our of an rsx-s at a junk yard for 1500 and the shop by my house is only chargin like a 1000 to drop it and get an ecu. so...the deals are out there. just gonna find em. prices are coming down slowly. remember....b series used to be expensive as hell. now every broke chunth on my car has a ricer that goes sorta fast.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97spooncivic &raquo;</TD></TR><TR><TD CLASS="quote">dont forget the problems about smogging and passing bar with a k, which i have yet to see been done legally. The only thing i have herd is turning it into a flex fuel vehicle, which seems like a pain</TD></TR></TABLE>
actually one guy got it to pass in an eg. it was a k20 from an rsx. but...he swapped over the engine and EVERYTHING from the engine bay (exact wiring) as well as cutting the rear of the car up to run the rsx gas tank and fuel pump and he even swapped the dash (i doubt this had anything to do with passing it). but yea to pass legally that is a lot of work and more importantly a lot of money. besides....my ls vtec doeswnt pass either so when i pick up a motor swap and start to build...i dont really worry about passing. i guess its just the risk you take. with with the 5000-6000 you're going to spend on dropping a k series (a STOCK k-series) you could buy and turbo an lsvtec or a b20 vtec. so...i guess its just in pure bling factor. k series motors are just status icons. lol.
imma stick w/ my lsvtec unless i find a k series for cheap. my buddy MIGHT be swapping out the k series in his EP for a tsx motor....so i'll take his k20 for cheap. he said about 1500 bucks. so...thats cool and it has intake header and cams i think.
Old 12-23-2006, 08:41 AM
The_Head's Avatar
I believe you don't hear about it because only one of the K24 motors will take a K20 head without having to swap out the stock pistons, and I think it was the K24A1 from the Accords.
Old 12-23-2006, 09:53 AM
Syndacate's Avatar
Ah thanks guys.
Pretty much got what I was looking for. Yeah, I didn't know there were so many types of K engines.
Expensive *** swap though (and i had no intentions of doing it, I was simply wondering about it).
As far as BAR goes, NY, baby, no BAR, emissions, or CARB crap here as long as you're 95 or &lt;.
Though even if you're 96+ the emissions tests aren't bad - NOWHERE near where u guys have to sell ur right ******** to get your car to pass in Cali .
Seriously had no idea there was this many K motors...******* new cars, jeez.
Oh well, as time progresses the swap will go down in price and become more popular as things are created to ease the process.
Old 12-24-2006, 05:29 AM
6SPD_EK's Avatar
Default Re: 2.4L swap? (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">I believe you don't hear about it because only one of the K24 motors will take a K20 head without having to swap out the stock pistons, and I think it was the K24A1 from the CRV.</TD></TR></TABLE>
corrected
Old 12-24-2006, 06:15 AM
lhsabes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">I believe you don't hear about it because only one of the K24 motors will take a K20 head without having to swap out the stock pistons, and I think it was the K24A1 from the Accords.</TD></TR></TABLE>
Only the k24a2 out of the tsx and k24a1 out of the element will take a type s head without swapping out the pistons. And people do use the k24 out of the elements, heres a video of a k24a1/k20 turbo. http://videos.streetfire.net/s...1.htm
k20rex
29
03-05-2014 12:30 AM
racereaper7
12-31-2007 12:30 PM
zolutar
12
06-09-2003 07:52 AM
Screamer
04-24-2002 12:19 PM
Quick Reply: 2.4L swap?
