k24 swap
Re: k24 swap (banned)
The k24 is a bigger k20. Ive heard of people doing k24 blocks with the RSX typeS head. IE crvtec conversion. With the RSX head and the k24 block it should make for a very powerful motor.
The k24 should bolt up to the civic - although im not 100% sure. You should give hasport a call and ask - they would know for sure.
liam
liam
Re: k24 swap (liam821)
my friends were telling me to swap my motor for a k20a2 or k24 and i have an 02 civic (theyre crazy educated with that ****) so im guessing it will fit in a si. while we're on the subject, can you do a b series swap into 02 civics?
Re: k24 swap (crs)
Re: k24 swap (crs)
Hasport has swap kits for the K series into the 02 Civics.
Yes, the K24 is the same block as the K20. It like the previous generation B18 - B20 relationship is a larger bore and possibly stroke.
Re: k24 swap (Spade)
Don't the 7th gen Civics come with the old D-series motors, which have basically the same mount points as the B-series? Only the Si has the different mount points for the K-series motors.
Re: k24 swap (IM ALL BOB)
your correct cheesefrog.. and I would rather choice a k20 ITR motor..over the k24 any day..
The D17A2's mount points are not the same as a B's- otherwise youd see plenty of B series in 7th gens by now (2001 GSR/Type R's in 2k1 Civics)...you should see how many of these threads are created a day over at 7gcivic.com.
Can you do it? With the right amount of money.
Is it worth it? Nope.
Re: k24 swap (wizzards581)
why put rsx-s vtec head on to the crv k24 when it has vtec also?? mayb i would rather go wit the rsx-r...
vtec now = ivtec
vtec now = ivtec
Juniorhatch
05-26-2006 07:15 AM
