Which mount kit HCP or hasport
Old Jan 15, 2003 | 03:08 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Which mount kit HCP or hasport
thanks and why
Old Jan 15, 2003 | 03:22 AM
chad174's Avatar
Default Re: Which mount kit HCP or hasport (MugenHonda)
Well, I just got the new HCP 4-mount kit for my crx w/ b18. the front tranny mount isn't going to fit without some cutting and welding, and one of the rear mount bolts comes too close to the rear mount bracket to completely tighten. Other than that, these look real nice and high-quality. I heard the HAsport ones fit a little bit better. just what i know...
Old Jan 15, 2003 | 06:39 AM
badCRX's Avatar
New User
Default Re: Which mount kit HCP or hasport (chad174)
The HASport ones are a perfect fit. I did a guys swap with the HCP kit and the front mount would not work with the rear mount in. The first shift linkage would not go into 5th or reverse. Got another shift linkage from them and it worked. The HASport in my car worked perfect the first time.
Old Jan 15, 2003 | 06:49 AM
BseriesHatch's Avatar
definetly the hasport mounts. My friend used those mounts at it fit perfect.
Old Jan 15, 2003 | 06:56 AM
wuhungsixxx's Avatar
New User
Default Re: Which mount kit HCP or hasport (Novtec)
both nice mounts...i run the older non-billet Hasports...the new billet Hasports are super nice
Old Jan 15, 2003 | 07:02 AM
UncleBen'sRacing's Avatar
ok well aparantly u dont know how to put a mount kit on correctly, i have HCP mounts on mine and all my mounts fit perfectly, in order to install teh front mount you have to lower the front crossmember get the bolt in and then bolt it back in, it says so in the instructions if you read them....
my rear mount i had NO problems with, all in all i like my HCP's the front mount is solid, and the motor does not move not even 1 mm even banging on the rev limited ( i know i have tried)
also for the price i got my whole mount kit and shift linkage for 280 from a friend who onws his own shop, he no longer does or i would shoot yall his email... however u can find it all for easily under $400, and that comes WITH linkage not extra like HAsport, not to say HAsport isnt great they are, however they put the motor slightly too high, the motor has some movement due to only 3 mount setup and the linkage is $180 more i mean damn, not to mention the front mount is $60 more, so all in all 375 for hcp or 600+ for hasport
"i have made my choice" -homer simpson
thx
stephan
Old Jan 15, 2003 | 10:14 AM
SteveeeO's Avatar
Default Re: Which mount kit HCP or hasport (AllMotorEF9)
$600 + for HASport?... http://store.hybridgarage.com/
HASport all together is $530... and from the comments in my post a while back, HASport was the way to go
[Modified by SteveeeO, 2:16 PM 1/15/2003]
Old Jan 15, 2003 | 01:03 PM
keenspeed's Avatar
i have done two motor swaps using the hasport kit and i like it alot and plus it looks klean and lines up good! hopefully i help out.
Old Jan 15, 2003 | 01:34 PM
Hunter's Avatar
Default Re: Which mount kit HCP or hasport (keenspeed)
no experience w/ HCP, but hasport is nicey nice
Old Jan 15, 2003 | 02:12 PM
spettinger's Avatar
Default Re: Which mount kit HCP or hasport (Hunter)
i have the first hcp's, and it feels like my motor is flopping around, even with all 4 mounts. i am not too impressed. i have heard the new mounts are harder? perhaps energy suspension inserts??
Old Jan 15, 2003 | 03:14 PM
Kidnkorner's Avatar
Default Re: Which mount kit HCP or hasport (2ndhandCRX)
i can get complete hasport kit for B16 for $210, they are 2 miles from where i work, and they are close personal friends with my boss.
Old Jan 15, 2003 | 03:52 PM
Default Re: Which mount kit HCP or hasport (Huggy Bear)
600 , 530 im sorry i was 70 off
and yes the new HCP motor mounts do have polyurethane energy suspension type inserts in them, and a solid metal front, my motor does not move AT ALL
CornerCarvin
May 6, 2007 09:01 AM
Jockobo
11
Aug 31, 2005 08:17 PM
Adam.
Nov 1, 2004 02:00 PM
0554
10
Mar 5, 2003 10:29 PM
Turbo EG6
Oct 28, 2001 07:38 PM
