How long can my CV joint last
i am going to see if it needs to be replaced tomarrow, it started popping tonight, but the boot is good. just started tonight, how long you think itll last.. (axle on a b20Vtec) would u recommend takin it real easy from now on?
the rubber boot on mine got cut and grease came out, but there is no noise or vibration at all, been like this for about a month waiting tell i can hear a knocking noise then i will replace the axle.
[Modified by HondaGSR, 2:27 AM 1/15/2003]
My passenger side axle is slinging a little grease. I cant find out where its coming from though, it seems to be in tact. I guess i'll take out the axle and examine it closer. Its been re-booted before.
Well all i can say is that all you guys are driving on borrowed time!! Why chance it? That not really something that i would want in my mind at 100 + on a mountain road, or rush hour traffic. IMO
Does anybody know how difficult it is just to replace a cv boot and not the whole axle? Mine just started spewing grease out, not sure how long its been doing this for though?
It isn't very hard, but its time consuming. If your outer boot is torn, you still have to remove the inner boot to gain access to the outer boot. Its messy as hell but if your axles aren't knocking just the boots can be replace. IMO 60 bucks and a lifetime warrantee at autozone is the way to go.
Just fix it. Today I changed the axle, transmission fluid, ball joint boot. All that took about an hour, so it's not time consuming. Better safe than sorry.
well i found out what it was, it wasnt the CV joint after all, it was my lower cusco bar just looser than my X girlfreind's ***. tighted, and pops went away
GReddy SI
12
Jul 17, 2003 04:07 AM
