Stuttering problem
Old Jan 14, 2003 | 06:45 PM
Kamin's Avatar
Default Stuttering problem
Ok first
Background: about a month ago i took my transmission off to have it replaced with one because reverse didnt work, car sat from dec 6th to today.
problem: under low throttle the car stutters from about 2000-4000~ and it also happens from 5k+ under wide open throttle
no check engine light.
now I replaced my timing belt and alternator while the engine was out of the car, but it idles totally normal.
also i cleaned the engine thoroughly while it was out.
IM thinking
1) bad gas, went stale.
2) water in the spark plug
I also havent rebled the coolant after the first run and fan comming on.
any suggestions are welcome (REVERSE WORKS THO!! WOOHOO )
Old Jan 14, 2003 | 07:20 PM
Shawn C's Avatar
In The Garage
Default Re: Stuttering problem (Kamin)
you got water in the plug wires or plugs. replace them. trust me on this man. i had the same problem and spent about 300 bucks finding it. but i would bet $100 that its betwen the coil and the end of the plug (ignition, somewhere) hope this helps, kamin
[Modified by 22lbGS-R, 4:43 AM 1/15/2003]
Old Jan 14, 2003 | 11:15 PM
Kamin's Avatar
Default Re: Stuttering problem (22lbGS-R)
yea i pondered this all night at work, thats the only thing i can think of
im gonna go throw my stock wires back on and see what happens.
well the number 1 and 2 cylinder plug wires had water on the stem
how would i go about drying those? time? hair dryer?
the #2 plug was wet. i think i found the winner.
[Modified by Kamin, 12:36 AM 1/15/2003]
Old Jan 15, 2003 | 12:12 AM
Kamin's Avatar
dried plugs with hair dryer
put stock wires back on till i can dry the MSD's
car works again
wheee
Old Jan 15, 2003 | 07:23 AM
Shawn C's Avatar
In The Garage
cool. i knew it had to be plug wire related. i fried a set of magnacores on my teg, and it was doing the same exact thing, so some NGKs came to the rescue. glad you got it
austinkli
23
Feb 7, 2008 12:57 PM
redricer
Jul 25, 2007 07:19 AM
ChingonGSR
Jan 17, 2004 10:44 PM
Batoutahell
Apr 25, 2003 05:21 AM
