turbo parts
does anybody know if it is possible to buy replacement parts for a turbo. I found an old turbo lying around my pop's shop and decided to yoink it, the only problem is that the area where the oil flows into the turbine has a rust hole. is there any way to fix this? if so, any information would help. thanx alot. peash out
i don't know the part number, it's a mitsubishi and it came off of a ford so my pop's says. i'm assuming the standard stock T3/T4 turbo. its about the size of the one that come stock on the eclispes
it's definately not a t3/t4 as it more than liekly came off of a Probe or a turbo thunderbird... I haven't done much research on those two cars, so I don't know exactly which ones they use.. if it is the same one as the eclipses it's a 14b, however, I'm pretty sure its not the same turbo... sounds like you'll be spending barrells of money(not realyl, relatively cheap to rebuild) on that turbo but you should definately figure out what it is first.. does it have any numbers and **** on it? or is it too rusted to make out?
it has numbers nice and clear, are you able to bring up info on it? i will have to post again tomorrow, the turbo is in the trunk at the shop. i'll check it out and put it up asap right after work. thanks for your time maan.
got the model number for the turbine: 4448992
and another # below this one PE04H
if anyone can referance these numbers and tell me what kind it is it would be greatly appriciated. thanks for everybody's time
AspectIndustries
Oct 15, 2007 04:03 PM
