Engine Rebuild parts..
JW if anyone has the parts for the bearings/seals that you would replace when re-building an engine. Basically I want everything to be fresh, etc.
Also doing pistons/rods, etc. So non of that shtuff.
Rod bearings, Crank bearings, Cam and Crank seals, and Piston rings.
On the top I would replace the valve seals and have the entire head and block "hot tanked" to clean them.
suhweet. Thats the info I was looking for, but this thought just popped in my head. Does Honda offer a package deal with seals/bearings for rebuilds or am I gonna have to piece that together myself.
-navin
-navin
what car is this for? i may have the part #'s on hand.
if taking off the head, get the head gasket set, and also get the block gasket set. they'll have pretty much everything you'll need in there. and then get ACL bearings, unless you want to start matching #'s an colors from the crank, and go stock. camp1320.com, earl, and rocket are distributors of the ACL bearings.
[Modified by 98civicEX, 3:22 PM 1/14/2003]
what I have planned for is..
GSR block
ITR head
SI tranny (not that it matters, thought id throw it in there)
GSR block
ITR head
