Changing the timing belt
Old Jan 14, 2003 | 06:22 AM
NAZC's Avatar
Default Changing the timing belt
Whats the best way for me to remove the crank pulley on an A6 engine, I tried using just an impact gun and it didn't move
Old Jan 14, 2003 | 07:07 AM
REDBARON's Avatar
Default Re: Changing the timing belt (NAZC)
Put transmission in gear, and set the parking brake.
Old Jan 14, 2003 | 09:30 AM
turbo sol's Avatar
Default Re: Changing the timing belt (REDBARON)
take the cover off the flywheel by the oil pan and stick somethign in there to catch the teeth while you break the bolt loose.
Old Jan 14, 2003 | 09:38 AM
CRzex's Avatar
New User
Default Re: Changing the timing belt (turbo sol)
LOTS of liquid wrench, a breaker bar and a long pipe.
Old Jan 14, 2003 | 11:03 AM
zCivic's Avatar
Default Re: Changing the timing belt (CRzex)
Get 2 breaker bars and a Mac tool morosso also makes one, made for honda crank pullies. Other wise the screwdriver or something in the fly wheel or one of the holes in the crank pully. Its a rough job, good luck.
Old Jan 14, 2003 | 11:37 AM
Red_Si's Avatar
maybe i'm lost but do you have to take off the crank pulley when doing a timing belt??? i always thought you didn't???
Old Jan 14, 2003 | 11:47 AM
Superhatch's Avatar
Default Re: Changing the timing belt (Red_Si)
I didnt think so either..just use the tensioner and loosen it up.
-Jake
Old Jan 14, 2003 | 12:03 PM
sicivic's Avatar
Default Re: Changing the timing belt (SuperHatch)
Yes, you have take the crank pulley bolt off. The crank pulley keeps you from being able to take the tan timing cover off.
Old Jan 14, 2003 | 01:37 PM
NAZC's Avatar
Default Re: Changing the timing belt (sicivic)
I think I can get it, thanks for the help
Old Jan 14, 2003 | 02:07 PM
kyle h.'s Avatar
first i tried with my standard 200 foot lb., after that failed...i used my buddies 730 foot lb. impact gun, didnt work. then he let me borrow his impact gun from work. 1200 foot lb. worked like a charm.
Old Jan 14, 2003 | 06:04 PM
90da's Avatar
Yes you do....it takes time and alot of swearing but it does come off. If you know someone at a dealer try to get the tool that fits inside the pully to hold it in place, it makes it so much easier to get the bolt off( takes off at least 4-5 swear words)
Old Jan 15, 2003 | 04:52 AM
zCivic's Avatar
Default Re: Changing the timing belt (90ef)
I had mine on a engine stand Thankfully I think. Got the mac tools for the crank pully put the breaker bar on it, put another breaker bar on the nut, let the breaker bar for the crank pulley hit the bottom of the engine stand, put another bar over the breaker bar for the nut and it came of within 5 mins. I was alot easier then any other time I've done it. I really suggest that tool, its a miracle worker. Also you can put something in the holes but may end up ruining some tools thats what I did, used about 3 screwdrivers til I found one strong enough.
Powered by VTEC
Jan 29, 2008 05:58 PM
dfabulous
10
Dec 9, 2007 11:00 PM
1994CivicGS-R
Mar 19, 2006 08:06 PM
IA95civicDX
11
Aug 16, 2005 05:48 PM
crxcess
Feb 19, 2004 08:24 PM
