Oil leaks/having trouble trying to diagnose
Old Jan 13, 2003 | 09:23 PM
all420's Avatar
Default Oil leaks/having trouble trying to diagnose
Hey, I have an oil leak on my 4th gen '90 accord EX. There are many spots of oil on my driveway from where I park. so I try to follow the leak through my engine bay, but I see no easy to find streams. I can't see where it's leaking from.
Where would I start to diagnose this problem? Valves? Or something of the like?
Thanks,
-Nick
Old Jan 14, 2003 | 01:31 PM
4doorH22's Avatar
Default Re: Oil leaks/having trouble trying to diagnose (all420)
Is your motor oil level definitely going down? It might be tranny oil or any number of other dirty, thick fluid.
Check the periphery of the entire oil pan, drain bolt and oil filter to make sure it's not leaking there. Check the valve cover gasket too. If oil is leaking from somewhere else, that is not good.
Old Jan 14, 2003 | 01:43 PM
jspark79's Avatar
420,
Easy fix
Why don't you put a flat cardboard box under your car, and check in the morning where the leaks are.
Then jack up car and check it out.
Old Jan 14, 2003 | 01:45 PM
YeuEmMaiMai's Avatar
Default Re: Oil leaks/having trouble trying to diagnose (jspark79)
420,
Easy fix
Old Jan 14, 2003 | 02:13 PM
all420's Avatar
Default Re: Oil leaks/having trouble trying to diagnose (YeuEmMaiMai)
Thank you for the really helpful information guys! To answer the above question, yes my oil keeps going down...alot. I have to put in a quart or so about every 2 weeks, maybe even less than 2 weeks.
But, I will try that cardboard trick tonight and let you all know.
Thanks again
Old Jan 14, 2003 | 02:26 PM
4doorH22's Avatar
420,
Easy fix
Oh, yeah, that'd be the smart thing to do first.
Old Jan 14, 2003 | 03:29 PM
jspark79's Avatar
A QUART EVERY 2 WEEKS !!
You got a problem man. I remember seeing a thread about some recall or something concerning a gasket I think?? ---->Search: recall in Accord OR look back 3/4 pages
Better take it to the dealership and pay the $$ to get it done right.
Old Jan 14, 2003 | 08:44 PM
Broman78's Avatar
maybe an oil pan gasket. Cause i have to replace mine and i might as well do my vaule cover gasket while that is being done.
[Modified by Broman78, 5:45 AM 1/15/2003]
Old Jan 14, 2003 | 08:48 PM
ArchAngel Sabastian's Avatar
New User
the seal that was recalled if busted would take 2mins to leak out all your oil not 2 weeks.. he has a cracked old gasket somewhere.
try oil pan, valve cover... actually why dont you engine degrease that bad boy power wash it get all the old gunk oil outta the way, start it up and watch it see if you can tell where it comes from.. just an idea.
Old Jan 14, 2003 | 09:33 PM
all420's Avatar
Default Re: Oil leaks/having trouble trying to diagnose (ArchAngel Sabastian)
Thanks again for all of the great help.
What would it cost me to go to a dealership and have them look it over for me? The reason I ask this now, is because the nearest Honda dealership for me is 45 minutes, so I am seeing if anyone know's ahead of time.
Now, when it comes to degreaseing your engine, what do I do? Just buy something from advanced and hose it all down? Isn't there something I have to cover up like the dist. or alternator?
Once again, thank you all...
Old Jan 15, 2003 | 09:04 AM
btw that recall expired already so he is Sorry Out of Luck on that one.........
oil pan gasket or where the oil level sensor plugs into the pan, valve cover gasket
PunchedGuava
28
Sep 8, 2013 11:23 AM
fackyou
Jul 7, 2006 12:24 AM
hondaracing1
Aug 19, 2004 05:16 PM
Campee
Sep 5, 2003 11:19 AM
