Is this d16y8 intake manifold from a auto or manual, and why does it matter?
Old Jan 13, 2003 | 07:51 PM
Si-Yaaa!'s Avatar
Default Is this d16y8 intake manifold from a auto or manual, and why does it matter?
I would like to put a y8 mani on my 91 Civic Si, and from what I've read they bolt right up, but you have to use the y8 throttle body, fpr, and fuel rail, right? And I also hear that it must be from a manual because the IACV is on the intake mani on a manual mani, and on the throttle body on an auto y8 mani. So why does it matter if it's on the throttle body or not? I assume it's because the a6 IACV doesn't bolt onto the auto y8's throttle body spot for the IACV. I hope I'm makeing sense, but let me know if I need to clarify. Heres the pic of the one I'm interested in, but the person won't get back to me to me to tell me if it's an auto, or manual. Here ya go!
To me, it looks like it's from an auto. But I'm not pro.
[Modified by Si-Yaaa!, 4:52 AM 1/14/2003]
[Modified by Si-Yaaa!, 4:55 AM 1/14/2003]
Old Jan 13, 2003 | 08:04 PM
ViperRedCRX's Avatar
Default Re: Is this d16y8 intake manifold from a auto or manual, and why does it matter? (Si-Yaaa!)
run a 90-91 ls throttle body, no iacv, and it's bigger
Old Jan 13, 2003 | 08:34 PM
Si-Yaaa!'s Avatar
Default Re: Is this d16y8 intake manifold from a auto or manual, and why does it matter? (CRX-T)
Well, that IM was sold, so I won't get that one. But I still don't get why it matters. Thanks!
---Evan
Old Jan 13, 2003 | 09:42 PM
CRX-RX's Avatar
You've got it backwards, the IACV is on the back of the manifold on the automatic, which is similiar to the 88-91 setup, and on the manual it is located on the bottom of the throttle body. Also the automatic manifold is easily spotted by the large EGR valve on the throttle body side of the manifold, and a plate underneath the fuel rail. It doesn't matter too much which one you get, it's just what ever you have. IF you don't have a throttle body that has the IACV on it, then you would need to use an auto, if you do then you can use a manual.
Old Jan 14, 2003 | 11:36 AM
Si-Yaaa!'s Avatar
Default Re: Is this d16y8 intake manifold from a auto or manual, and why does it matter? (CRX-RX)
Wait, so with my 91 Civic Si, then I should get a intake manifold from a automatic d16y8, right? Then could I just use my throttle body or just take off the EGR valve an plug it up, or use and ls throttle body like said above? I'm kinda new to swapping intake manifolds. Thanks for all the help!
---Evan
Old Jan 14, 2003 | 11:52 AM
zCivic's Avatar
Wrong you need a 5speed intake manifold. If you have a automatic you need to switch the fast idle control valve and replace and work the Y8 manifold to accept it. Get the 5sp and it bolts right up and sensors all plug in, need to add a IAT to your intake piping because the Y8 doesn't have a spot for it. Reason because the 5 speeds IVAC uses the round 2 prong plug while the auto use a oval 3 prong plug no way around it. You can run the auto and have CEL
Old Jan 14, 2003 | 12:52 PM
Si-Yaaa!'s Avatar
Default Re: Is this d16y8 intake manifold from a auto or manual, and why does it matter? (zCivic)
Ok cool. You cleared everything up for me. Thanks man. I'll be looking for a manual y8 mani.
One more thing: Am I right that from a y8 I need the IM, the throttle body, fuel rail, and fuel pressure regulator? Do I need all of them, or can I use my Throttle body? Sorry for all the questions, and thanks for all of your help.
---Evan
[Modified by Si-Yaaa!, 9:53 PM 1/14/2003]
Old Jan 14, 2003 | 01:12 PM
4drEF's Avatar
Keyboard Humorist
No CRX-RX... you have it backwards. Go look at Hondaautomotiveparts.com for reference.
Old Jan 14, 2003 | 10:37 PM
Si-Yaaa!'s Avatar
Default Re: Is this d16y8 intake manifold from a auto or manual, and why does it matter? (4drEF)
I just need to clarify one more thing: Am I right that from a manual y8 I need the IM, the throttle body, fuel rail, and fuel pressure regulator? Do I need all of them, or can I use my Throttle body, fuel rail, and fpr? Sorry for all the questions, and thanks for all of your help!
---Evan
Old Jan 15, 2003 | 01:48 AM
CRX-RX's Avatar
How about I just look at the one in my room that's been here for the past couple weeks. The one with the big EGR valve on it.
Old Jan 15, 2003 | 04:32 AM
zCivic's Avatar
How about I just look at the one on my 90 DX with a Z6. Its a manual will post picks thursday when I get Internt back at my house, to show you what is needed.
Old Jan 15, 2003 | 12:47 PM
Si-Yaaa!'s Avatar
Ok, sounds good.
Old Jan 15, 2003 | 01:07 PM
Malgerus's Avatar
wrong. My manual tranny D16Y8 had the IACV on the back of the intake manifold
DarkDaysX6
Jul 9, 2013 05:53 PM
titi_vtec
Jun 29, 2010 07:59 PM
03akkord5spd
Feb 21, 2007 10:07 PM
alacard
Dec 25, 2006 11:30 PM
spun Vtec
Jun 6, 2003 03:59 AM
