How is the USDM rad support saved
when you do a jdm front conversion teh spot welds are punched out of the usdm rad support right?
my questions on this, sorry if it sounds stupid... but like punching out the welds on the usdm bumper will still make it reusable later on?
and like the rebar and everythign else should be alright?
i couldn't find anything on the jdm posts ppl said, no one talked about the usdm parts after
i know probably cuz no one cares or whatever else, but wnated to know if anyone couldbe of help
depends on how it was drilled out.
len
I wonder how much a USDM conversion would be worth in JDM land...
I doubt much considering they could just go to a junkyard and get one. the "JDM" front end is not the only G3 JDM front end they had.
finding a buyer yourself may be difficult in japan.
itr-j, your question was already answered btw.
[Modified by Soup ****, 7:29 AM 1/21/2003]
Correct. If drilled out correctly using proper tool, spot welder drill bit, then the radiator support can be reused later on to reverse the conversion.
len
len
markpaco
Dec 3, 2016 04:40 AM
