on which engine to swap to 85 civic
Old Jan 13, 2003 | 05:10 PM
mexipino26's Avatar
Default on which engine to swap to 85 civic
My boy has an 85 civic that does not run well we are considering an engine swap?
I just want to know if anyone has any suggestions on which engine to go with and if you can give us some advice. anything will help. This guy wants $500 for 89 crx si engine with tranny, axles ecu,harness we are not sure if it will work. thanks
Old Jan 13, 2003 | 06:13 PM
Shawn C's Avatar
In The Garage
Default Re: on which engine to swap to 85 civic (mexipino26)
the 1.6L DOHC non-vtec engine in the 86-89 integra (im thinkin its the D16A1, but dont hold me to that) is a direct bolt-in for that car. and you can normally buy the whole car for about 600-1000 bucks, so you can also have all-wheel disc brakes, etc. a good friend of mine just took the whole wiring harness out of the teg and now his civic is teg wiring from headlight to taillight. it took him about a week, but its quick as hell. also, the engine is the DOHC non-VTEC ZC engine in Japan. good luck.
Old Jan 13, 2003 | 06:37 PM
mexipino26's Avatar
Default Re: on which engine to swap to 85 civic (22lbGS-R)
thanks I was just looking at that engine.
Old Jan 13, 2003 | 07:25 PM
Shawn C's Avatar
In The Garage
try an talk him into buying a totalled 86 integra that runs. his civ will turn into a sweet little car for cheap.
Old Jan 14, 2003 | 08:28 AM
mexipino26's Avatar
I think we are going to be going to some yards here in San Diego hope we find a good deal.
Old Jan 14, 2003 | 11:12 AM
Shawn C's Avatar
In The Garage
good luck mang, thatll be a fun-*** little car.
Old Jan 14, 2003 | 12:17 PM
eg6ajk's Avatar
if the car is a carbed 1500s or 1.3l carb, then no other swaps you can really do. just drive the car off the cliff as 76hp (about 45-55whp, (we dynoed one)) is as much as you'll get.
if the car is Civic Si with 1.5FI motor then you can swap in a 86-7 Teg motor but much of the drive train and upgrades will be required (best to pick up a whole Teg and simply swap over everything) that includes suspension (rear discs), motor, tranny, axles, front suspesnion, ECU ++++ much more.
if you want something more exotic for your Si then there is the Hasport kit for to mount a b16a/b18c/b20 with cable tranny
for carbs another option is a Weber side drafts or Mikunis looking at around $400-1000 for a set (guarantee that you'll break into 80whp)
Old Jan 14, 2003 | 12:40 PM
Shawn C's Avatar
In The Garage
Default Re: on which engine to swap to 85 civic (eg6ajk)
whoa, man we dont want them to die!! 80 hp is nutty! and if they get a whole teg, they can use any civic/crx for a base. my friend had an HF, and swapped over EVERYTHING. its basically a teg with a crx body.
Old Jan 14, 2003 | 05:46 PM
StorminMatt's Avatar
While it may be a chore to go from carb to EFI, it is not impossible. And in my opinion, it would be preferable to having the extra weight of an SI.
gagedally
Honda Civic (2001 - 2005)
Feb 3, 2013 06:01 PM
Meatwad1355
19
Dec 25, 2011 09:00 AM
bauer10
Apr 21, 2006 12:37 PM
Omen7
66
Jun 27, 2005 08:40 PM
coolusername
12
Jun 24, 2003 01:08 PM
