DRAG any good for SOHC?
Old Jan 12, 2003 | 11:59 AM
hatch101's Avatar
Default DRAG any good for SOHC?
well in my search for a turbo for my car i have come across the drag kit. these kits come with the t3/t4 right? which turbo would be best for my application? its daily driven, stock internals for now, will be built, and will be using hondata in the future. im concerned about lag with the t3/t4. well if you feel like it, help me out. thanks in advance. oh and the motor is a d16y8.
[Modified by hatch101, 8:59 PM 1/12/2003]
Old Jan 12, 2003 | 01:07 PM
T-sohctec's Avatar
Default Re: DRAG any good for SOHC? (hatch101)
Before I blew mine apart I was getting full boost(13psi) at 3000. That wasn't too bad for the amount of power I was making. Of corse I was only running a straight DP at the time
The thing I didn't really realize with all these spool times is that, yes you are only making full boost at X RPMS but your turbo is making descent power about 1k before full boost.
If this motor actually will be built later on your gonna want a turbo that can take advantage of those internals i.e. the ability to flow more psi up top.
Old Jan 12, 2003 | 03:15 PM
hatch101's Avatar
Default Re: DRAG any good for SOHC? (T-sohctec)
well then you are saying the drag kit will be good? im seriously thinking about this kit, and i know you have to choose the specs of the turbo you get, but im not sure what specs to go with.
Old Jan 12, 2003 | 03:36 PM
D-Man's Avatar
i gotta a drag gen 2,i bought it 4 years ago and i didnt have a choice on what turbo it came with,it came with a T3/04b.compressor is an "S" trim and the turbine is .48 a/r stage 3 trim..i guess its good to around 300-350hp.
[Modified by D-Man, 8:32 PM 1/12/2003]
Old Jan 12, 2003 | 07:16 PM
hatch101's Avatar
Default Re: DRAG any good for SOHC? (D-Man)
what about reliablilty of the actual turbocharger itself?
Old Jan 13, 2003 | 05:47 AM
D-Man's Avatar
well so far i got amost 35,000 miles with it with no problems or leaks...knock on wood
Old Jan 13, 2003 | 07:30 AM
P18AJ79's Avatar
I run the Apexi kit. Love it. It is Ballbearing. Great spool and i boost 5psi daily and 12 for the track. apexi is a very nice kit and i have been boostings 9-11psi for over a year now. Good luck bro on your set up
Old Jan 13, 2003 | 07:34 AM
hatch101's Avatar
Default Re: DRAG any good for SOHC? (MAKURAGI)
yeah i heard that kit was good man, but i can get the DRAG kit real cheap and thats probably what im going with. thanks for your support. ill keep everyone updated on my progress.
Old Jan 13, 2003 | 08:08 AM
leadtrum's Avatar
my friend had the drag kit on a 88-91 sohc and it ran pretty good till he went stupid with the boost...
he got like 220hp at like 7-10 psi without hondata, jus an fmu. if i was going to buy a kit though...i love my apexi and the great thing is...if you feel that you're running out of power with that turob....you could switch it out with the bigger IHI turbo that bolts right onto the manifold from what i heard
Old Jan 13, 2003 | 08:38 AM
hatch101's Avatar
Default Re: DRAG any good for SOHC? (leadtrum)
yeah they say those APEXi kits are real good.
Old Jan 13, 2003 | 08:44 AM
ill_take_one's Avatar
When you say good to around 300-350 hp, does that mean 300-350 hp on top of what your engine is already producing? or is it total? Do you understand what i'm trying to say?
Thanks
Old Jan 13, 2003 | 08:52 AM
leadtrum's Avatar
Default Re: DRAG any good for SOHC? (ill_take_one)
i'm assuming total....unless you built your engine to run like race gas and hold 15-20 psi
Old Jan 13, 2003 | 02:07 PM
D-Man's Avatar
Thanks
Yes.i got it..its total
Old Jan 13, 2003 | 02:19 PM
Ok, thanks man thats all i needed to know
Old Jan 13, 2003 | 02:29 PM
D-Man's Avatar
anytime
Old Jan 13, 2003 | 03:35 PM
SOHC_power's Avatar
I have that kit on my car. Same motor. I haven't got it tuned yet, so I don't know what kind of horsepower I am looking at, but for the money I would go with drag. I've had mine on since September and no problems so far. (Once you get the bugs worked out). I run 5psi daily and 9psi at the track. I reach full boost about 3300. Here is a thread I posted the other day. https://honda-tech.com/zerothread?id=380858 I know people with the greddy kit that only run 15's.
If you are buying the sale kit from Importparts take what they say about shipping eta's loosley. They told me 2 weeks and it took 2 months. Not badmouthing them or anything, just sharing my experience. Be prepared to spend money. Good luck.
Hey you guys running APEXi, what 1/4 times and hp#'s you makin.
Old Jan 13, 2003 | 03:41 PM
ExospeedAMcrx's Avatar
Default Re: DRAG any good for SOHC? (SOHC_power)
drag kit is good for the advertised 6-7lbs of boost its designed for.. and then some.
its a good upgradable system that you can boost more with proper fuel management and block work.
REV HARD is great as well...
Wil
mrbsponge
Sep 16, 2004 10:11 AM
Turbo-Honda
Apr 25, 2004 03:51 AM
DefiantGSR
Jan 19, 2003 07:59 PM
superduperman
Nov 2, 2002 11:26 AM
