bad hub... swap
I think my hub has gone bad... I can't get my axle back into it. I spent hours tring to put it back in, and it can't be done. I have a spare axle, and it won't go in either so I'm led to believe it is the hub... iut was vbery difficult to get out in the first place.
My question is (and I already did a search
), I want to try to get a used spindle assembly (becaues a new hub and wheel bearing will probably be $$$). Which one will interchange with my 1993 civic SI hatch?
I found a guy in town who has a set of civic EX spindles, but he says that he tried to swap it onto his buddies civic si and the caliper mounts were in a different spot... so the caliper would not fit. Will this spindle not work on my car? If so, what civic shold I look to raid?
), I want to try to get a used spindle assembly (becaues a new hub and wheel bearing will probably be $$$). Which one will interchange with my 1993 civic SI hatch?I found a guy in town who has a set of civic EX spindles, but he says that he tried to swap it onto his buddies civic si and the caliper mounts were in a different spot... so the caliper would not fit. Will this spindle not work on my car? If so, what civic shold I look to raid?
9honda5civic
Mar 22, 2020 09:57 PM
Zeronamous
11
Oct 12, 2015 07:40 PM
civicdelsol33
Suspension & Brakes
Aug 27, 2008 06:33 AM
