A little history on Specs
HONDA INTEGRA Type-R
1995.9 : TYPE-R uses an improved 200-hp dohc 1.8-liter 4-cylinder engine with VTEC variable valve timing and front-wheel drive. LSD
It was available only with a 5-speed manual gearbox. Type-R's standard equipment includes leather wrapped steering wheel, RECARO seats and a shift **** made from titanium.
1998.1 : Torque figures are up mildly at low and mid rpm levels(4-1 header), and huge disk brakes(5 lug started) and larger tires were used for the improvement in brake performance. Also Type-R has had its operating performance enhanced.
Engine improvements:
Equal-length 4-in-1 style stainless steel exhaust manifold.
Adjusted final gear ratios deliver enhanced power.
Handling improvements:
15-inch front disk brakes and 14-inch rear disk brakes.
215/45ZR16 tyres and newly designed 5-hole 16-inch alloy wheels.
Completely retuned suspension for a sportier, firmer driving feel.
Other improvements:
SRS airbag-compatible steering wheel designed by MOMO.
High Intensity Discharge (HID) headlights with twice the brightness of halogen lamps.
New wing-type rear bumper design.
1999.7 : The serial number stamp which shows the order of manufacture is started. (in japan) (US started in 1997)
Other improvements:
what do u mean "wing-type" rear bumper?
Where can I find a set of these JDM 15" brakes that fit under 16" wheels
Some of those specs sound a little off like the brakes. You run a "JDM parts" store or something? Sounds like you're trying to sell us on some JDM poop.
edit- saw the 15" brakes comment, still it's misleading
[Modified by SurferX, 8:50 AM 1/12/2003]
I think this post is an explanation over the posters ad in the classifieds.
https://honda-tech.com/zerothread?id=380828
[Modified by Louie, 9:26 AM 1/12/2003]
I heard this too. I remember the Lancer Evo always had 17'' rated disk brakes. And this is when it had 17'' wheels, so I am almost positive that they rate it by the max wheel size for teh brakes to clear.
you are correct
VTEC-LUDE
13
Nov 16, 2006 09:19 AM
crxaddikt
Feb 10, 2004 08:55 AM
