DSM 450cc + AEM EMS =?hp
What is the limit of the DSM 450cc injectors in a 10.5:1 T4 boosted motor? I was thinking around 15psi, but an article in HCI told of a Teg that was running 22psi w/9.1:1 compression running on RC 310cc injectors. I have two sets of DSM injectors, and I would like to hit 400-500whp...has anyone else done so with 4 of these injectors, or should I hook up all 8 and configure them into the AEM EMS?
check out this link:
http://www.rceng.com/technical.htm
Any experience with running more than 4? Trying to save money, but if it wont work, then it wont work....
I could figure that out no problem, as I have luckily been pretty good at doing stuff like that. Here are my options:
1) Fabricate something at the TB to mount the extra 4 injectors. Drill and tap my fuel rail for 4 barb fittings, and run high pressure/stainless hose to each additional injector.
2) Drill and tap the fuel rail, and somehow mount the injectors directly in the manifold(preffered I think).
Any other ideas? This would effectively give me 900cc injectors. 900cc injectors alone would cost about $500. This setup would cost me a couple hours of thinking, and maybe an hour of actual work....
K, Im purchasing AEM EMS this week because of its HUGE range of possibilities. Im going to run 8 DSM 450cc injectors by running soemthing similar to the following program...
http://www.aempower.com/bbs/viewtopic.php?t=5
