FAQ: Axle Replacement Tutorial With PICS!
Old Jan 11, 2003 | 09:06 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Axle Replacement Tutorial With PICS!
Ever hear a clicking noise when you turn?
Ever feel a vibration only when you're acclerating?
Chances are that you need a new axle. The first thing you'd need to do before you go pulling an axle out of your car is figure out which axle is bad if both aren't. Symtoms of a bad axel would be:
1. Torn boot with grease slinging out.
2. One side or the other vibrating upon hitting the gas. This indicates a broken or worn inner joint.
So after you figure out which one (or both) needs replacing you can begin.
I've taken some pics of various tools that you will need in order to swap an axle. I work at a shop so air was available to me, but for you at home there might not be some tools pictured here that you will need - I'll get to that in a minute.
32mm socket
19mm socket
17mm socket
17mm wrench or additional socket
1/2'' driver for big sockets
3/8'' driver for drain plug/sockets
hammer
dykes
prybar
*big-*** breaker/cheater bar for the 1/2'' driver to break the axle nut loose and tighten it back down*
*Optional*
Depending on tranny you might have to drain and fill the tranny. I make this a common practice every time I swap an axle and I recommend that you do too. In my tutorial I will detail how to drain and fill the tranny. If doing so add these things:
3 qts of Genuine Honda MTF (you won't use all 3 - B-Series takes like 2.5 qts.)
Long funnel
crush washer for drian plug (get it from Honda - same one as your engine oil drain plug)
10mm socket with LONG extention
driver for 10mm socket/extension
Here we see the various tools laid out. Missing from the pic is the big-*** breaker car for you at home that will need it for the 32mm axle nut. Also missing are the funnel and 10mm socket.extention/driver combo for the drain/fill procedure. I has air tools available so I used them.
Close-up of cotter pin (you'll only need one) and drain plug washer
Drivers and 17mm end wrench:
32mm, 19mm, and 17mm sockets:
And if you're lucky and have tools a 1/2'' impact will be very helpful:
Okay so let's get started.
1. Take the 19mm socket and break your wheel lugs loose. they will be hard as hell to break loose if you've already got the car in the air.
*For those without an impact*
It has been brought to my attention that if you are using a 32mm socket with a 1/2'' driver and a big-*** breaker bat you might want to break the 32mm axle end nut loose while the car is still on the ground. Hopefully you can access the nut with the wheel still on, because if not you'll have to get someone to sit in the car and hold the brakes on with the engine on in hopes that the wheel won't turn while you try to break the 32mm nut loose.
2. Jack up the car and secure it on a STABLE set of jackstands. I used a lift so sorry, no pics.
3. Locate the drain plug and use a 3/8'' driver with no socket and remive the drain plug:
Replace the drain plug washer and tighten the drain plug back after draining is complete. I didn't do this until later on because I waited to drain the tranny until right before prying out the axle, but I recommend doing this first at home and then tightening the plug back until you feel/hear the washer crush. This insures no leakage during work and also so that you remember to drain and tighthen the plug up before you start the real work.
4. Remove the wheel and look for the 32mm axle end nut. Yeah the pic sucks.
5. Remove the axle nut with the 32mm socket. At home you will need a breaker bar or cheater bar to get much-needed leverage to break this bastatrd loose. I used an impact.
6. Now find the cotter pin lovated on the 17mm castle nut below the lower balljoint and remove it by unfolding it with your dykes:
7. Now take the 17mm socket and remove the 17mm castle nut from the lower balljoint. Yes this pic sucks too.
8. Now take your hammer and beat on the lower control arm where the hammer head is in this pic. This will break the balljoint loose. The pics get better sometime.
9. Now locate the through bolt that holds the lower strut "fork" to the lower control arm:
10. Using a 17mm socket on one side and either a 17mm wrench or another socket to hold the other side, remove the through bolt .
11. Now take your hammer and LIGHTLY tap on the end of the axle to get it free from the spindle:
12. Now pull the lower strut fork to the side and it should all look like this:
13. Now you're ready to pry the axle out. Take the prybar and position like so in the pic and pry. You might want to secure the spindle out of the way so it doesn't hold the axle in:
14. Compare your new axle to the one you pulled out and make sure the new axle is correct. The old axle might not "look" bad, but in this case here the shaft is actually broken in half inside the outer boot.
15. Now you're ready to put the new one in. Simply reverse the removal procedure. First get the spindle out of the way and pop the axle back into the inner joint. It might take a bit of pushing, but it will pop in. Make SURE that the inner joint is all the way in and butted up against the tranny casing fully.
16. Here's where steps can be swapped around, but I did mine in this order. Put the lower balljoint back into the lower control arm and slide the outer splines back into the spindle - finger tighten the 32mm axle nut on so the axle doesn't pop back out while you do other work.
17. Now you're ready to line up the lower strut fork with the lower control arm to put the through bolt in. It helps to tighten the lower balljoint 17mm castlenut first. Replace the cotter pin too! VERY IMPORTANT!!! Remember to tighten the 17mm castlenut in a manner so that you can slide the new cotter pin in.
18. Push up on the lower control arm and slide the through bolt in plave and put the 17mm nut on the end:
19. Using two 17mm sockets or whatever combo you choose, tighten the through bolt:
20. Now tighten the 32mm axle end nut. If you have no air tools then use the breaker bar and tighten it up pretty snug. STAKE THE NUT DOWN! Use the hammer and something flat to make an indention in the nut like pictured:
So the new axle is in. Time to fill the tranny. There's a few schools of thought on how to fill the tranny, but this methid here is by far the least messy and to me the easiest.
*Optional* Find the fill plug. It is seen here right next to the inner joint of the axle. It has a crush washer so if you loose it your'e screwed. Honda doesn't usually sotck this one. I chose not to loosen my fill plug because I know my tranny takse 2.5 qts., but the way you fill it is to fill until fluid dribbles from the fill hole so this is optional if it makes you feel better.
Here's where the trick comes in that will save you headahces. Usually you have to ghetto-rig a funnel and tube to fill the tranny in the fill hole which really sucks. My method is really easy.
1. Remove the vent cap found near the front/top of your tranny:
2. Find the Speed sensor located on the topside of the very back of your tranny:
3. Take the 10mm on a big-*** extension and remove the bolt (it's the orangish one in my pic - yours probably won't be oragnish):
4. Now see that big-*** hole left after you move the speed sensor out of the way? Use the funnel and fill through that hole! By the way, no need to unplug the speed sensor - just move it out of the way.
5. Fill up with specified amount or until fluid dribbles from the fill hole below.
6. Put the speed sensor back in, tighten up the fill plug (if you loosened it).
7. Replace the vent cap and you're done!
Now put your wheel back on, torque the lugs to spec with a torque wrench and take your car for a test drive!
Modified by B18C5-EH2 at 11:12 PM 9/25/2008
Old Jan 11, 2003 | 09:12 AM
nfiedler3's Avatar
Default Re: Axle Replacement Tutorial With PICS! (B18C5-EH2)
I am sure it will be helpful to many...
Old Jan 11, 2003 | 09:17 AM
HybridHatchC1's Avatar
Default Re: Axle Replacement Tutorial With PICS! (nfiedler3)
nice, and i didnt know you could fill the tranny like that, where do you work agian tom, looks like an awsome shop.
Old Jan 11, 2003 | 09:18 AM
lazy bum shaughn's Avatar
Old Jan 11, 2003 | 09:20 AM
acydphryck's Avatar
cool....thanks for the highly detailed steps...i'm gonna have to drain my tranny fluid and this should help out quite a bit.
Old Jan 11, 2003 | 09:22 AM
Evs-One's Avatar
Solbros Owns Me
Nice, Tom!
Question- isn't it bad to use an impact on the axle nut?? If one squeeze of the trigger pops it off, then cool, but I know some people let it sit there and poh poh poh- let it keep impacting the nut. I've heard this is bad for the tranny. What have you heard?? And most likely it won't do anything since most people change axles once in their life if that
Old Jan 11, 2003 | 09:24 AM
CsabaH's Avatar
Very good write up! I personally have been taking off the fork completely to ease install and removal of the axle. The only thing that I would add to this write up is that if you are not using an impact for the 32mm and using a cheater bar, you will need to put the car back on the ground w/ the center cap removed on the wheel that the axle is being replaced. That way the other tire will not spin while trying to remove the 32mm axle nut.
Everything else is dead on, I never tried the speed sensor trick
Old Jan 11, 2003 | 09:27 AM
eg6ajk's Avatar
Default Re: Axle Replacement Tutorial With PICS! (CsabaH)
never seen anyone fill up their oil throught the speed sensor....
originality
Old Jan 11, 2003 | 09:30 AM
usdm_ED7's Avatar
Default Re: Axle Replacement Tutorial With PICS! (eg6ajk)
genuine honda mtf....
Old Jan 11, 2003 | 10:04 AM
ill phil's Avatar
Default Re: Axle Replacement Tutorial With PICS! (usdm_ED7)
Good write up! I swear there's like 10 people a week asking how to remove an axle- this will help greatly
Old Jan 11, 2003 | 10:58 AM
SiBirdie's Avatar
Default Re: Axle Replacement Tutorial With PICS! (ill phil)
very nice pic an really good info! good ****
Old Jan 11, 2003 | 11:03 AM
Kamin's Avatar
Default Re: Axle Replacement Tutorial With PICS! (SiBirdie)
christ...
i never once thought of removing the VSS to fill the transmission..
one thing tho
you never said to bend out the tab on the axle nut before you remove it.
good write up tom
[Modified by Kamin, 12:04 PM 1/11/2003]
Old Jan 11, 2003 | 11:07 AM
dom93hatch's Avatar
Some pics you forgot to add "/"
Old Jan 11, 2003 | 11:19 AM
Nameless RB26's Avatar
Default Re: Axle Replacement Tutorial With PICS! (Kamin)
christ...
AHHHH wtf have I been waisting my time for!!
I didn't even think about removing the VSS for this
Good ****, good ****!
Old Jan 11, 2003 | 11:39 AM
ace1875's Avatar
Another Great Advice from a great man of Help and Knowledge
Old Jan 11, 2003 | 12:01 PM
MilanoRex's Avatar
Default Re: Axle Replacement Tutorial With PICS! (ace1875)
How much different would this be on a 90 Integra LS? Thanks
Old Jan 11, 2003 | 12:07 PM
sleeprhatch's Avatar
Default Re: Axle Replacement Tutorial With PICS! (MilanoRex)
you sneeky bastard, that is how you fill up the tranny easily. thanks for the info is was good!!
Old Jan 11, 2003 | 12:51 PM
VWkila's Avatar
Default Re: Axle Replacement Tutorial With PICS! (sleeprhatch)
Thanks for the info!
People like yourself makes honda-tech.com best on the net!
Old Jan 11, 2003 | 12:53 PM
Pengo's Avatar
the VSS thing is a really good idea i hate filling it from the side
yea for those without an impact you may wanna unstake and loosen the axle nut first before you even jack the car up. especially if you've never taken the axle nut off before, those things can be tight.
Old Jan 11, 2003 | 12:59 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Thanks for the additional info on the axle nut if you don't have air tools.
Old Jan 11, 2003 | 02:25 PM
FUP23's Avatar
New User
Wow~! Great tools ....I' think Ive changed around 10 sets of axles so far! Great write up couldve said it better myself
Old Jan 11, 2003 | 03:22 PM
99DXcoupe's Avatar
That was really helpful thanks tom
Old Jan 11, 2003 | 04:58 PM
AWD: Jeff's Avatar
Default Re: Axle Replacement Tutorial With PICS! (SI-racer)
damn. now i wont worry so much on my axles.
Old Jan 11, 2003 | 05:12 PM
speedaholic92's Avatar
Default Re: Axle Replacement Tutorial With PICS! (Dohc93hatch)
that oil trick is GREAT!!!!!!!!!
Old Jan 11, 2003 | 05:19 PM
Fuster_Cluck's Avatar
Default Re: Axle Replacement Tutorial With PICS! (speedaholic92)
Sure this will be useful when I go to drop my GSR in the Eg
