HELP!! Cant figure out where leaking??
Old Jan 10, 2003 | 01:27 PM
vtec69's Avatar
Default HELP!! Cant figure out where leaking??
I just installed a new headgasket on my ls/vtec and when i started it up nothing leaks. But when the car gets warmed up i see oil dripping from under the cam gears. So i put some high temp silicone on the corners of the valve cover and waited approx 14 hours and started it back up. After about 5-10 mins of idleing I saw oil dripping again from under the cam gears.
Could it be my cam seals????
Or is it maybe the silocone didnt fully dry and it gets melted when the car gets warmed up???
Please help me I miss my LS/VTEC
TIA
-Brian
Old Jan 10, 2003 | 01:37 PM
sgT's Avatar
sgT
Default Re: HELP!! Cant figure out where leaking?? (vtec69)
new cam seals?
Old Jan 10, 2003 | 01:38 PM
Misfit's Avatar
Default Re: HELP!! Cant figure out where leaking?? (sgT)
new cam seals?
UHHH... roger that. over.
Old Jan 10, 2003 | 02:07 PM
vtec69's Avatar
Default Re: HELP!! Cant figure out where leaking?? (MISFIT)
EDIT: I meant oil seal not cam seal
-Brian
Old Jan 10, 2003 | 02:32 PM
RTW DC2R's Avatar
I had a very similar problem...it was actually dripping all the way down to the head gasket from behind the distributor, and we thought it was the head gasket...major pain in the ***. I got new cam seals and distributor o-ring, same thing happend. I got a new valve cover seal and a good amount of hondabond and that seemed to correct it.
Old Jan 10, 2003 | 02:38 PM
sgT's Avatar
sgT
those are cam seals. are they new?
Old Jan 10, 2003 | 02:39 PM
Ricky Rojales's Avatar
Hondabond?
Old Jan 10, 2003 | 02:42 PM
Mugen Mike's Avatar
Default Re: HELP!! Cant figure out where leaking?? (HT Kleenex)
Hondabond?
Yes
Old Jan 10, 2003 | 04:07 PM
Tweakmeister's Avatar
Default Re: HELP!! Cant figure out where leaking?? (MugenMike)
don't use silicone...
Old Jan 10, 2003 | 05:28 PM
io_burn's Avatar
New User
Default Re: HELP!! Cant figure out where leaking?? (Tweakmeister)
Hondabond. I bet that's good **** (Anything with Honda in the name has to be good, that logic hasn't really failed me yet.)
Out of every "game"
Apr 16, 2006 02:41 PM
Out of every "game"
Apr 16, 2006 02:14 PM
vtec69
Jan 10, 2003 05:31 PM
vtec69
Jan 10, 2003 04:56 PM
vtec69
Jan 10, 2003 02:06 PM
