problem gettting car into gear..
hey guys i been having problems shifting ...basically i can't shift into any gear except when the rpms are below 3k...is this a tranny fluid problem..sychros or clutch..??
If it's all gears you are having the problem with all the gears then it's probably not your syncros. Could be your clutch going out. I couldn't upshift when I went over 3.5K. Pulled the clutch and it was fried. After installation of new clutch no problems shifing.
[Modified by Eva01, 9:33 PM 1/10/2003]
is there any squeaking or whiney sounds coming from your car when you put your clutch in. If so I had the same probelm and it was my throw out bearing. I couldn't shift into any gears above 4k RPM's. still had trouble below that also. Anyways I just replaced my clutch with an ACT and while I was at it I replaced the flywheel so it all worked out for me and hopefully once it is installed will make my car a little quicker
