CLUTCH ?????????????
WAT IS WRONG WHEN IT IS HARD TO SHIFT FROM 3rd gear to 2nd gear....????????i just change the tranny fluid so that aint the problem..is it the clutch ??????????? 98 gsr
dude, we're going to need some more info. Is it only when you're downshifting from 3-2? Does it only happen when downshifting? upshifting? How does the pedal pressure feel? Stock clutch? Did you bleed the clutch hydraulic system? Do you push the clutch pedal down all the way?
double clutch when you downshift 3 to 2. If that works it be your synchros.
I know it is your car and all BUT, THERES NO NEED TO BE A DRAMA QUEEN!!!!!!!1
Exactly , what he said, but if it is hard to get into all gears, and its not grinding then its your throwout bearing and you need a new clutch. Also another common problem is your pressure plate might be going bad. I had the same problem and I have a clutch on the way. If it was your synchros it would be in certain gears (hopefully) and it would grind into them. Go ahead and start with the clutch and if that works , great. if not, invest in a tranny
litterbox
Sep 28, 2005 09:41 AM
