Cam Install - what should i replace?
I am getting ready to throw in a set of cams in my ITR. Wondering what i should pick up at Acura this weekend to have and replace after we put in the new cams. I think there are seals on either side of both cams correct? I am not going to replace the valve cover seal. I already have a new timing belt to put in. I am having a buddy help me do the install. Anything you guys would reccomend replacing while i am in there to be on the safe side and have no leaks?
mike
mike
cam seals, hondabond, maybe some extra valve cover studs since those break rather easily.
maybe some oil to do a fresh oil change afterwards? just a suggestion
good luck
good luck
how many miles?
cam seals are nice and easy to do while the cams are out.
the car has 41k miles on it. BTW, stock cams will be for sale
so cam seals..i will do an oil change at the same time, anything else? i will get some hondabond.
mike
timing belt, cam seals, valve cover gasket, spark plug gaskets, water pump, valve cover gasket washers....
sure you can skip the above... but come on you wanna do it right, and save yourself some trouble in the future
I 44K miles i wouldn't bother replacing anything but the cam seals. Everything else should be fine. Just use a little hondabond and your set. Don't forget the valve adjustment
nexgen91
Jul 31, 2007 07:08 AM
