Bench race your ideas of "turbo stages" & other REQUIRED upgrades.
I was wondering if we could put together a listing of "turbo stages" and other upgrades. Maybe something like revhard has on their site [ http://www.revhard.com/turbokits.html ]. Only I'd like to see a listing of clutch choice etc. Only required upgrades to handle the power though (no suspension mods etc.). An estimated price would be nice, and if it's been built and used let us know!
I can do the turbo's
Specify the brands you want and I'll do it. Maybe someone will make it sticky. I can even convert the efficiency levels for each one and map them in real world numbers. IE tell you which rpm on which motor will provide whatever turbo to create so much boost with so much efficiency. Does that make sense? It'll maybe take a week or three depending on how hard it is to find the compressor maps, and to do the actual math. I like these kind of projects they keep me busy when I'm bored. Which is all the time. Just tell me what you want done as far as turbo brands and trims. I can't do A/R unless someone specifies the exact A/R, but I can do approximate spool up rpm.
[Modified by tzsir, 11:14 AM 1/11/2003]
I got some for ya-
garrett t3/t04e 60 trim/.63 a/r stage 3 wheel
t3/60-1 .48 turbine .72 compressor
garrett t3/t04e 57 trim/.63 a/r stage 3 wheel
On a stock ls motor with 2.5 inch exhaust and external wastegate
InfamousRS
Jan 16, 2002 06:17 PM
